Question about Welding Tools
Where can i get a pcb for a spotmatic f class spot welder
Main pcb 880-456-000 need schematic to troubleshoot.
Dana, Sorry no schematic, but I do remember the welders may of had bad circuit boards
Jan 23, 2016 | Welding Tools
My telwin mig welder feeds the wire just no spark ..frustrating. .any ideas
Sounds like the pcb needs repairing or replacing it may not be giving out the voltage required to pull in the contactor or relay.
Oct 09, 2015 | Welding Tools
Asahi Pentax Spotmatic SP jammed shutter
Have the film come to the end of the roll and the camera will not fire, if so rewind the film. Sorry, a shutter is not a self service item. This should be sent in for a CLA.
Nov 04, 2013 | Pentax Asahi Spotmatic Sp 35mm Film Slr...
I have a cig 220 I pull trigger to feed wire no wire or sounds happen welders fan is running wire isn't jammed and drive motor is working
first of all check the wiring from the machine to the torch then check that the thermal cut out light isn't illuminated, operate all switches and test on all settings, check the relay on the pcb and any contactors in there if all the above fails to find the fault then chances are a part on the pcb have failed
Oct 30, 2013 | Campbell Hausfeld Welding Tools
Tip of pilotscrew is broken off and stuck in carburettor of Yamaha XJ900s diversion '2000
spot weld a screw to it using a MIG welder, make sure you take the carb off the bike 1st, and that its free from fuel, or vapours, else it will catch fire, once a screw is welded to it, use that screw to undo your other, as they are now classed as a complete screw, it should come out with ease.
Hope this helps!
Apr 30, 2011 | 2000 Yamaha XJ 900 S Diversion
MANUAL FOR A MAGNA SPOT 1500
To get a manual. Here is a link to the contact information for Magna spot welders by Motorguard. Hope this helps.
http://motorguard.com/contact.html
Mar 29, 2011 | MotorGuard Magna Spot 1500 Stud Welder...
NO , I'M TAKING COURSE IN COLLEGE AND NEED A SCHEMATIC FOR ANY WELDER FOR THE CLASS !!!
1-216-481-8100 call that number and ask them for one for a AC-225 this is a basic entry level welder.
Oct 19, 2009 | Miller Welding Tools
SIP 195 MIG welder doesnt work
sounds like your welder has over heated and the Thermostat has come on
wait for 10 minutes and then try again
If that does not work fit a new PCB
Gilmore
Jan 01, 2009 | Computers & Internet
Welding Tools Logo
62 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
