Question about Toshiba 62HMX84 62" Rear Projection HDTV
Flickering and freezing of picture for a split second
Hey, i have owned my 52 inch toshiba dlp tv for going on 3 years now and havent had any problems till recently. i noticed my picture will flicker and the image will freeze up for a split second and then it will work fine till it does it again(probally 5-6 times every hour). not sure if this is a sign that the bulb needs replaced or something more major?
  • 1 more comment
  • Anonymous Nov 12, 2007
    i have the same tv..i have had it for almost two years ...it just started flickering...time to replace the bulb so soon????
  • Anonymous Mar 16, 2014
    My Poloroid TLX - 04243b 42 inch tv is having an issue. Picture is fine but sound is choppy as if muted for split seconds. The show will play smoothly so I know the entire system is not choppy just the sound is. Any solutions?
    Problem Solver:
  • 5 Answers
The most likely problem for image problems and flickering is the lamp (23311083A). I found it at PartStore.com for about $180. Hope this helps.
Posted on Nov 16, 2007
Toshiba 52" dlp has picture but no sound
audio circuit problem, you have ruled most of the simple things out.
Dec 16, 2012 | Toshiba 56HMX195 52" HDTV DLP Projection...
Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Toshiba DLP 60" TV not showing TV programs, sound ok
Have the tuner signal board replaced. HDMI does not use the regular tuner bands, it is bypassed when using hd inputs.
Aug 25, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
Flickering picture and color smear
Trash it Toshiba T.V. and laptops have a flickering problem with is caused by a failty power supply
May 27, 2009 | Toshiba 52HM95 52" HDTV Projection...
Picture getting darker over the years
It could be your Light Engine. However, I would first check a few things:
1. Make sure your Low Power/Lamp settings are adjusted so that they meet your brightness needs.
2. Make sure you used a Mitsubishi original lamp, as generics get chewed through fast and hard.
3. Try another lamp; sometimes you can get a bad one in the bunch.
All those things don't work, consider a Light Engine ($400 + for parts; $300+ for labor)
Mar 11, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
RCA TV flickering problem
Your tv has a video problem, leak capacitor in video section, near in flyback need to replace it.
Apr 14, 2008 | RCA L46FHD37 46 in. LCD HDTV
Screen Flicker
The answer here has to be generic guess. Without properly troubleshooting the set, this is a difficult guess.
This could be a power supply problem, or a clocking problem that deals with the decoding for the field rate.
Jerry G.
Mar 31, 2008 | LG RU-52SZ51D 52" Rear Projection...
Toshiba DLP 50HM66
The bulbs for this TV seem to go about every couple years. The price has dropped down a bit. I have found it for 118.00.
Feb 17, 2008 | Toshiba 50HM66 52" Television
Toshiba 46HM84 DLP Black and white pattern..
contact your dealer for service flashfor this symptom.(light tunnel)
Aug 11, 2007 | Toshiba 46H84 46" Rear Projection...
Toshiba 62HMX84 62" Rear Projection HDTV Logo
226 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
