Fe signal display in aircon unit - Heating & Cooling
What does exactly means 'INSP' in the aircon display of GW X240 4WD?
I am not sure something inspection or service,may you have to take to dealer.
Oct 11, 2016 | Cars & Trucks
Air conditioner blows hot air
For this problem, I would like to suggest you take help from any of the reliable servicing and repairing team.
I always prefer aircon service for any problem related to my air conditioner, as they are specialized in air conditioning servicing and repair.
Ranging from simple Aircon servicing to Aircon overhaul, they offer all kinds of services and solutions that you need in order to ensure the maximum efficiency of your unit. Also, they take reasonable charges for their various services.
Jun 27, 2016 | 1998 Lincoln Navigator
Display error code E6
E6 is a comms error try turning the power off at the isolator and reset everything. if it comes back you might have a lose interconnecting wire between the indoor unit and outdoor unit
Apr 15, 2014 | Mitsubishi Heating & Cooling
I have an split-type aircon (brand: Fukitsu) remote control AR-DL2. it has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift indoor unit cover and remove DC wire from display sensor. After 3 minutes again plug it and close the door. Now you try with your remote. If still problem, check your remote through cell phone camera by pressing any button in remote. If ultra light is visible thr' camera, remote is o.k. If remote is o.k, repair/replace PCB. Thanks.
Feb 09, 2011 | Heating & Cooling
TCL air conditioner works for about 15 minutes, switches off and gives a signal of 4 red flashes every now and then.
It's due to abnormality of out door unit. Clean condenser coil first. Check run amps. If gradually increases, replace running capacitor. Check rpm of f.motor. If slow, replace fan capacitor. If still problem, replace fan motor. Service indoor unit also. Thanks.
Feb 04, 2011 | Heating & Cooling
Amcor aircon 15000btu
Have you tried pushing the reset button on the power plug? If the unit overheats the reset button will click on and the a/c will turn off. In order to turn it back on you will have to push the reset button.
Jul 09, 2010 | Amcor PLM-14000E Portable Air Conditioner
Samsung aircon remote not working
Does your remote have batteries? If yes change them. Somewhere on the unit there should be a selector switch, put it into test and manually lower the thermostat setting
Feb 14, 2010 | Heating & Cooling
How do I remove stereo in 2009 Santa fe?
Remove negative battery lead
Pry plastic 'wood' trim off from l/h side of steering column (assuming r/h drive car) ensuring light pressure so as not to mark.
Contrinue to pry off trim towards stereo, last remaining clip on far side of car will not come off
Open top box above stereo, remove 2 black screws and remove unit.
Unscrew aircon/heater controls (2 screws either side), withdraw.
Working upwards, remove 2 fascia screws and withdraw unclipping wiring.
Reveals 4x silver screws holding in stereo unit. Withdraw unit, 1x manufacturer loom plug on reverse and 1x aerial plug.
Jul 17, 2009 | Hyundai Electronics W240D LCD Monitor
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
