York affinity 9.s series, year 2008. I have not used my furnace since last winter (approximately 7 months ago). I went to start it up this year for the first time and it will not start. Upon inspecting behind the bottom access panel the 3 amp at40 fuse on the circuit board was blown. I replaced the fuse and tried turning the power back on with the same results, instant blown fuse, as soon as I turned the circuit breaker back on. What will cause this to happen? Where do I start? Also my basement flooded this spring but the furnace is raised off the floor and was not submerged in water but there was all that moisture in the air for days if not weeks.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
Fuses will blow if there is an overload.
Breakers only trip if there is a short to ground.
Since you replaced the fuse and it blew and tripped the breaker , I would check for a wire problem. Also check the elements that rodents haven't built nests ect...
Posted on Nov 12, 2014
  • chase muehlbauer Nov 12, 2014
    Right, these were the first things I thought of two. First I checked the intake and exhaust pipes for plugs, all clear. I checked to see if the condensation line was plugged, all clear. Looked over all the visible wiring, also all good (as in like no chewed wires or mouse nests or nothing crazy). So I figured the problem must be wiring. I presumed from the fuse backwards to the main breaker. I haven't started digging into it I was just wondering if there was a typical or good spot i could start checking.
  • 124 Answers
SOURCE: York Air Handler trips main circuit breaker
almost has to be the electric heat strip coils. they usually come on in stages. when the damaged strip comes on it kicks breaker. turn off all power, check with a meter , gently remove strips and inspect for broken or shorted coils. usually best to buy a new heat strip module. they are usually held in place as a module with 4 screws and a snap together wire connector .good luck. i have had some success if the wires are broken and not to brittle by bending a minute loop in the end of each wire and reconnect with the tiniest screw and washer and nut you can find, i'm talking real tiny. about the size of a bb if you can find em , or you can remove the damaged strip wire entirely to get some heat from remaining.
Posted on Nov 23, 2008
solveditnow
  • 39 Answers
SOURCE: (HVAC) Furnace Not Igniting Quickly
Make sure a back draft in the flue is not happening. Wind can blow it out until the flue heats up. The flame sensor may not be close enough to the burner flame. It may be weak and need to be replaced or if its an optical one it may be dirty and not see the flame very well. Its not wasting much gas but it puts extra wear and tear on the gas controls, is noisy, and, as you said, blows cold drafty air. A gas control system that has issues of any kind is not real safe. It needs to get fixed.
Posted on Jan 08, 2009
pierre1811
  • 144 Answers
SOURCE: Code 32 when wind blows
Hi and welcome to Fixya. I believe that the wind is affecting the draft. What I would recommend is to install a cap on the flue that is similar to a weather vane in that it rotates to block the wind from creating a downdraft in the flue. Some times depending on the direction and strength of the wind it will come up over the roof peak and then down the flue. A regular fixed cap may work too. You should be able to purchase one at your local hardware store. Please let me know if this was helpful. Good luck.
Posted on Jan 25, 2009
t1m130
  • 86 Answers
SOURCE: York AC blown 3 amp fuse how do I replace?
the fuse is for low voltage 24v wires it is most likely located on the control board inside your furnace or air handler most of the time it will look like an automotive fuse there is probably a reason why its blowing usually a pinch or short in the wire if its a re accuring problem you might want to get a resetable 3amp fuse or popper i would be more concrned about calling the company and saying you charged me and never fixed the problem
Posted on Jun 28, 2009
shastalaker7
  • 1515 Answers
SOURCE: I have 60 amp circuit breaker on my electrical a/c
You're unit is a 31/2 ton according to the numbers.Normally, breakers will only be in a half way posistion when tripped. Yes, under most conditions, the fuse will blow before the breaker trips. I have seen this many times, the breaker may be weak, burned, loose wires and so tighten wires, check the condition of the breaker.It sounds like the breaker even though it is 60 amps, is the problem and you should replace it with out hesitating. This will solve you're problem. When you pull the breaker out, look at the metal clips that snap in on the buss bar to see if they have been overheating.And the buss bar its self. You will know. I am sure this will take care of you're problem. Good Luck,
Shastalaker7
Posted on Dec 07, 2009
Testimonial: "Thank a lot this was very helpful"
Affinity 9.s, York furnace, 4 blinking red light/code, changed filter, doesn't reach requested temp. and stops.
Well change filter but if filter is clean you might have a restriction on your return vent.
Make sure vent is clear
Dec 26, 2017 | Heating & Cooling
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
Honeywell RTH2300 says Heat On, but furnace isn't running.
Your tstat is not the problem. I've not yet worked on an oil furnace. I'm way down south. But either way, if your tstat was calling for heat(heat on), and you pushed a reset at the furnace, more than likely that reset is a safety. OK to reset, but now what ever that safety is preventing from happening, has failed and can not be reset until repaired. The reset should be an automatically opening switch upon unsafe operation. And manually closed to "reset" the safety. That safety is connected to something that is not working properly. Hope this helps!
Mar 02, 2017 | Honeywell prgrammable thermostat RTH2300B
Furnace blowing warm air, ac overheats
Sounds like it is tripping on it's high pressure switch. This could be caused by a dirty condenser coil, overcharge of refrigerant, or non condensables in the system ( air most likely). I would get a second opinion from a repuatable company, sounds like he's trying to rip you off.
Sep 25, 2012 | Bryant Heating & Cooling
Why does my furnace gas valve keep going bad
Check the ground wire to the gas valve or the wire in the middle of the gas valve that says mv--pv, and that is a ground..
Dec 19, 2009 | Heating & Cooling
York 92 % eff. furnace shuts down on # 3 error (pressure switch)
i have fixed almost every one of pc9 -----we have installed in our company,code three{flashes} at first new presure switches installed, same thing,york knows about this,induction motor bearings,could be bad.our local york dist, has boards,inducer, ***.motor, dual press.switch,free.as is known as the only way to fix.after all else is ruled out.one local competator called us if we wanted to join class action suit . good luck.furnaces work good at first, season or two then bam
Nov 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
York furnace coding 9. which is ground or polarity fault. what do i look for?
I put a new control board in my York today and it was a different/newer board. I immediately had the 9 code thrown at me for grounding and polarity issue. All I had to do was switch the 2 gray wires on the transformer. The gray wires go the the 12 pin connector. The new board is wired differently.
Aug 02, 2009 | York Tools & Hardware - Others
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
TH8320U1008VisionPro8000 honeywell thermostat with Affinity York
Take a multimeter and check your rh and w terminals. With the face off, you should get 24 volts. If you do not get 24 volts, turn the power off, and check the continuity, you should get ol (open load). Now if you do not have 24 volts, and the meter reads ol, there is a problem in the wiring to the thermostat. My only concern is the green light blinking slowly, but if that is normal on your unit, I will let it be. Hope this helps
Mar 24, 2009 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
