Question about Car Audio & Video
Whats the best way to wire 2 12" sony xplod xs-l1237 subs to a kenwood kac-7204 amp hooked to factory radio on 2000 ford explorer?
I am hooking up a kenwood kac-7204 amp to a factory radion in a 2000 ford explorer that also will be having 2, 12" sony xplod xs-L1237 subs . already had hooked up but my kenwood amp got way too hot and was smoking and blowing fuses what am I doing wrong?
  • 3 Answers
You have the ohm load at 1 your amp i
Posted on Nov 27, 2014
5 Suggested Answers
SOURCE: my kenwood KAC-7204--- the wiring
when i was running my sub off bridge mode this kept happening to me. I ended up just running two subs and for some reason the fuse stopped blowing. i think there is something wrong with these amps.
Posted on Sep 22, 2011
  • 87 Answers
SOURCE: kenwood kac-7204 1000w amp with 12 in sub what
bigger the better my friend. Look at your Peak RMS output, and how long of wire you need. Then you could make the judgment call on how thick or what gauge you need. (2 involved factors power + distance). id say 10 gauge and you would be fine.
Posted on Jun 03, 2009
  • 102 Answers
SOURCE: have kenwood kac 7204 2
Hi you run them in sterio two 4 ohm subs sterio two 8 ohm subs you can run mono or four 4ohm subs can be run in mono also
Posted on Feb 05, 2010
drsinister69
  • 2317 Answers
SOURCE: XM-2165GTX Car Audio Amplifier: i have a kenwood 1000watt amp model # kac-7204 i h...
I would try to remove the top cover of the amp and you might be able to push them out from the inside. Just a shot in the dark.
Posted on May 19, 2010
How to install kenwood 729s withno rca outlet on radio
You can run the speaker wires to the speaker level input on the amp or i believe you can run another set of speaker wires spliced into the existing wires in parallel to the speaker level input along with the speakers that are already hooked up if you are using the amp for a sub or other speakers that you have added to the existing system.
Apr 14, 2014 | Kenwood KAC-729S Car Audio Amplifier
My kenwood KAC-7204--- the wiring is hooked up right, I just got a 2000 watt max sub 1000 watt rms, i was running the amp in bridge mode and it ran for 1 day than it turned off. I checked it and the fuse...
Jun 04, 2011 | Kenwood KAC-7204 Car Audio Amplifier
Power is hooked up. Ground is connected. Both subs are connected. The triangle light is red, and there is now sound. All wires are hooked correctly...
on most amp red isnt good that means it in protection mode try turning your setting on the amp down all the way and turn the volume down tell you can get sound out of them then turn up the volume to were you would to them most and set the to what sounds the best but make sure the light doesnt dim down when the base hits
Jan 16, 2011 | Kenwood KAC-7204 Car Audio Amplifier
I have 2 10' sony xplodes connected to a 2
If your radio is still playing and the subs are giving you music, you most likely have the amp remote wire hooked to a constant power source on the radio. Generally, this is a solid blue wire on both the radio and the wiring harness. It allows the radio to turn the amp on and off when the radio is on or, subsequently, off.
Apr 21, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I bought a kenwood kac 7204 amp yesterday and i hooked it up to one 12 and one 10 and it sounds good but it gets really hot and it even shuts off do you know what might be my problem??
What is the impedance you are driving. If the load is too low then it will cause the amp to go into thermal shutdown. Look up the recommended impedance for this amp.
Dec 29, 2009 | Kenwood KAC-7204 Car Audio Amplifier
Blown amp possibly?
i have the same amp with the same problem.....your best bet is to do what i did get a better amp(audio pipe,spx,kicker,punch,etc) do not get pioneer amp or sony anything
Jun 20, 2009 | Kenwood KAC-X501F Car Audio Amplifier
Kenwood kac-7204 1000w amp with 12 in sub what size wires nedded to use
Jun 03, 2009 | Kenwood KAC-7204 Car Audio Amplifier
Car Audio & Video Logo
105 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
