Question about Vacuums
How to take apart a McCullough Steamer - Vacuums
Dirt devil easy steamer deep cleaner instructions
go here> http://dirtdevil.com/file/1549/
Nov 24, 2013 | Vacuums
My shark steamer is not heating or steaming
I posted this video explaining how to clean the heater core.
http://youtu.be/S4NglGXVv50
Tons of water on the floor might mean that an internal hose or hose clamp has failed. Once you have it apart you can assess and replace the hoses by taking the bad hose to the auto parts store and asking for an appropriate sized replacement.
Dec 18, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Took apart head of sharp steamer S3501; cannoat reassemble. Where can Iget a diagram of how to reassemble?
I just posted a video showing how I took apart and reassembled the S3501 to clear the heating core.
Nov 12, 2012 | Vacuums
Hoover agility steamer lower hose broken
take the handle screws all out and take the black peice where the hose attatches to loose. then pry handles apart gently and the hose peice will be able to be reached. not easy but can be done.
Feb 21, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Scuncii Steamer
It is probably clogged with rust or limescale - can happen with steam cleaners. Sadly there's no way around this but to try a limescale remover in distilled water such as Calgon limescale remover. Fill the kettle as normal and give it time to boil up. Then release the steam as you would normally. You may find that the kettle will spurt out deposits of gunk. Sounds like its definately clogged though.
Feb 19, 2009 | Scunci 52067 Handheld Steam Vacuum
Bissel steamer
You can do this Jeremy just be take your time be patient and keep trying!
Jan 21, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No steam in scunci steamer will not work lights uop hear pressure and heats up
no steam in scunci steamer, it does gets warm but no steam at all. like if it was blocked
Aug 29, 2008 | Scunci 52001 Handheld Steam Vacuum
Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Jul 15, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
