Video Cameras Logo
B
Brenda Posted on Nov 12, 2014
How do I hard reset a Vivitar DVR 980 camcorder?
After turning on the unit, I can see the backlight on the LCD turn on. The actual icons and stuff flash on for a second then go away. I can still see the backlight, I can press buttons on the LCD touchscreen and hear responsive feedback, but nothing is shown on the LCD from this point. I'd like to try hard resetting the camcorder to see if that helps.
5 Related Answers
Anonymous
  • 169 Answers
  • Posted on Aug 11, 2007
SOURCE: No display in viewfinder and LCD
sorry to say but the problem of your camera is the ccd image sensor....go to a service center for replacing it...
Anonymous
  • 55 Answers
  • Posted on Aug 25, 2007
SOURCE: Non-Responsive PDA
You may have to do a hard reset. You hold one finger at the power and the other hand hold your stylus and his reset. This technique is applied to most PDA.
Anonymous
  • Posted on Nov 27, 2007
SOURCE: PRESS THE RESET SWITCH error message
Same here also. PV-GS9
Anonymous
  • 3 Answers
  • Posted on Feb 12, 2008
SOURCE: help,,, camcorder when turn on says "to service " and turns off
see this
http://www.fixya.com/support/t301818-error_displayed_service
Anonymous
  • Posted on Sep 06, 2008
after reading the above solution, a few swift taps to the bottom got it to work. I guess it is just be careful, but if it happens - show it some tough love
My cameras power button turns on the camera but nothing works after that
I advise you to talk to the seller of the product concerned to see the options you have regarding the product.
2helpful
2helpful
2answers
MY VIVITAR 550 DOES NOT CHARGE AND DOES NOT TURN ON. WHAT IS THE PROBLEM?
Most likely your Vivitar needs a new battery....if you've lost your a/c adapter-you can use a standard USB cable to charge your camera. Plug the smaller end into your Vivitar & the larger end into your turned on PC/laptop & it'll charge the battery.
Vivitar DVR-530 5MP DV Camcorder cables for tv in/out. I need these cables.  Also the installation CD.
The install CD and cable should be included in box w/camera...
Vivitar brand was recently bought out by Sakar last year (August 21st, 2008) which means support is likely discontinued. I have the installation CD. One upside of cheap consumer stuff is buying direct online - from China! Check ebay, the cable looks generic enough.
4helpful
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
2helpful
3answers
Dvr550 by Vivitar
I need the driver for the vivitar dvr 550 to install on my computer. Where can I dowload one from?
Dani
Lcd Screen
Sorry to hear that!
The only thing I would sugest is to pull the battery (and leave it out for 24 hours (or longer)) to try to reset the camera. But I would guess that the LCD stoped working and the white screen you see is the back lit screen mounted behind the LCD.
Top Vivitar Video Cameras Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
