Question about Motorola Talkabout MT352R Two-way Radios, 35 miles Range, IP-54 Weatherproof
Why does my volume not return to normal levels after using a motorola headset? Is there a way to return the unit to factory settings?
I used a Motorola 1518 Surveillance Headset with PTT Mic which worked as described but after removing, the volume coming from the speaker remains muted and muffled. Mic volume on the receiving end is fine and all functions work properly but it's difficult to hear. I thought it may be a problem with this particular unit but I tried the other headphone (I bought a set of two) into the other radio same problem. I'm not sure if it's a setting that may have been tripped after using the headset (VOX or Noise Filter) but I'm not aware of all the features. What else can I try?
  • Mishan Kasiparsad Nov 12, 2014
    Press and hold for three seconds, then rotate clockwise to increase, or anti-clockwise to decrease volume level
    Master:
  • Motorola Master
  • 541 Answers
While this seems an odd situation,it is quite common. The radio volume is different through the audio jack than the regular speaker. You could plug the earpiece in and out with the radio on and it could work, and it may not be in the manual, but you should turn the radio off to remove the earpiece. The radio should also be off when you insert the earpiece. No, I do not have your exact radio in my hands, just 32 years experience with all makes of radios and earpieces. This advice has not changed in all this time. Also, the VOX feature is often engaged when plugging an earpiece into a radio that is already on.
Posted on Nov 15, 2014
    Sergeant:
  • 169 Answers
The volume control for the headset is typically the same one you use for the phone. plug the headset in again & use the volume control to increase/decrease volume as you require, remove the headset and use the same volume control to increase/decrease the volume on the device..
Posted on Nov 12, 2014
Testimonial: "There is no button, unless you are referring to PTT button. Also, I tried removing the headset and adjusting the volume. Likewise, I removed the headset and repeated the procedure. You do not seem familiar with this radio, but by turning the volume knob counter-clockwise it turns the volume down and eventually off. Clockwise rotation turns the radio on and increases the volume. The headset does not have a volume control switch."
  • Omar P
    Omar P Nov 12, 2014
    The volume knob is also the power switch on the radio. Removing the headset and repeating the procedure has no effect.
  • Mishan Kasiparsad Nov 13, 2014
    http://www.motorolasolutions.com/web/Bus...
Where is the volume
Little buttons on side of headset. Typically the factory setting is for right ear. So volume button on top would be up volume and bottom would be lower volume.
Mark
Motorola Support
May 20, 2014 | Motorola Mobility H371 Bluetooth Headset
VX-3000 microphone still enabled with headset. Is
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower drop-box display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Dec 31, 2009 | Microsoft LifeCam VX-3000 Web Camera
Webcam headset
Not sure this webcam includes a headset - check your speaker / audio settings
Vista
If you have an older OS - you may have to access your hardare from the Control Panel
TEST SPEAKERS
In lower dropbox display "Use this device enable" click OK
Restart computer
CONFIGURE TO MESSENGER
Dec 09, 2009 | Logitech Quickcam USB Zoom Webcam
Plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jul 10, 2009 | Plantronics CS55/HL10 Wireless Office...
M-S9 controls (Track up/down and pause) work fine. Volume up/down and mute will beep when pushed, but there is no audio ever. Using Microsoft Media Player on laptop. Computer see's the S9 and reports its...
Returned the motorola back to the store and got another brand. Did the full install (add Bluetooth) Had same problems.
My solution Was to go into Control Panel select speakers. Make the bluetooth speaker default. Check its properties (Level). and test (tones should play through headset).
Now restart your application (Media Player)
I'm running Vista 64
I hope the resolves Motorola s-9 problem (It is a much nicer headset)
Mar 21, 2009 | Motorola Mobility S9 Headphones
Cannot increase volume on my Motorola S 9 stereo headset.
The problem is that the unit is not immune to sweat as Motorola claims it is. Mine did the same thing with trying to lower the volume. You might try to dry it out good with a hair dryer (but don't get it too hot). That might help for a while, but eventually it will short out again and you won't be able to fix it. Sony just came out with a unit that is similar and I am going to dump the Motorola for the Sony to see if it works better.
Nov 25, 2008 | Motorola Mobility MOTOROKR S9 + Bluetooth...
Using Motorola Blue Tooth with PS3
Yes you can. Just go to accessories or audio device settings. Have your headset on and hit connect bluetooth device. The key it asks for should be 0000. If that doesn't work do a quick search online and you should be able to find one that works.
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Hi
The first 2 answers sound relay dumb but always start at the beginning when diagnosing a problem. 1: make sure you're not placing your thumb over the Mic (located at the bottom, front of the device). 2: make sure Mute is not turned on, if it is tap it to turn it off. 3: if your using handsfree mode try picking the phone up and using it normally. There's no Mic volume control in the standard Matchbox based GUI but some 3rd party software does include volume adjustments so take a look at your settings in any control apps you have installed. lastly see if you get the same problem using a headset, you have not said if you are using the phone normally, with a headset/BlueTooth headset or in handsfree mode. Post back if non of this helps.
Aug 23, 2007 | Motorola Mobility A1200
Motorola Talkabout MT352R Two-way Radios, 35 miles Range, IP-54 Weatherproof Logo
117 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
