<!-- from fixya rte -->Where can i find a blowermotor for my dv36rn - Heating & Cooling
    Master:
  • 478 Answers
I would suggest ebay, failing that try the manufacturers, most have spares divisions on their websites
Posted on Nov 12, 2014
Fan/heater does not blow any air
Check to see if you have voltage to the blowermotor, if not there is a resister:
If you do have voltage to the blowermotor, and it don't work, replace the blower motor. To access the blower motor and resistor, remove the glove box door, its all in that area:
You can also check this site, as they have done the repair:
http://honda-tech.com/showthread.php?t=2617460
Dec 09, 2013 | 1992 Honda Accord
No power to the blowermotor
You should always include the device in which it is installed since there are several possibilities that may influence the supply of AC voltage to the motor.
Some items can also be eliminated if you have a simple multimeter available at home.
These can be bought at electronic supply and auto parts stores for under $20 US- don't spend more, additional features or improved accuracy aren't necessary for most tasks.
Mar 27, 2013 | Emerson BlowerMotor, PSC, 1/2hp, 1075,...
Heater and ac work fine but only for about 20 min then the air stlops flowing.
The heat stops flowing this means the air stops blowing. i would say this is one of two things if its the air that stops blowing, this would be a bad blowermotor or the blowermotor resistor, the most common problem i would say is the resisitor, good luck, hope this is helpful.
Jan 10, 2011 | 1993 Buick LeSabre
What fuse runs the heater fan
The blowermotor fuse is located in the under the hood fuse box, its in slot # 12. this fuse is an orange fuse and is 40amp fuse, the most common problem with the blower not working is the blowermotor resisitor, so if the fuse is good try replacing the resistor this resisitor is loccated on the heaterbox next to blowermotor. hope this helps.
Oct 27, 2010 | 1996 Ford Taurus
Heater fan not working, new fuse fitted
This is very common, this sounds like the blowermotor resistor module, this is located on the heaterbox next to blowermotor, i would start there if all fuses are good, the other thing you can do to test motor before replacing the part is disconnect connector to blower and run a power and ground wire to it, if the motor runs then i would replace the resisitor. good luck hope this is helpful.
Sep 23, 2010 | 2000 Volvo S40
The first three setting for air control have stopped working, level 4 and 5 work fine. I was told that it is probable the relay inside the cab behind the glove compartment. Is this true or do I need a new...
There is a resister for the blower motor,it is near the blower motor,and mounts on the outside of the blower box,but actually goes inside the blower box to keep cool,this is your speeds for your blower motor,be sure and check the connector to it also,these will melt and burn up a lot of the times when this happens.you can get the connector and resister at the auto parts store,I know napa carrys it.Now the blower motor may run good and sound good,but this is the reason the resister goes out,the blower is pulling too many amps,so replace it also,or you will have to replace the whole thing again in a month,thank you,and if this was at all helpful,please rate.
Jul 20, 2010 | 2001 GMC Sierra 2500HD
Heat will not blow
check all your fuses first , then check the blowermotor for power and ground,if it has power but no ground then replace the blowermotor resistor. hope this helps.
Feb 18, 2010 | 2001 Hyundai Santa Fe
Trying to locate the blowermotor resister on a
The blower motor resistor gets really hot so it is located where the blower motor fan can keep it cool. Look under the hood close to the blower motor.
Feb 12, 2010 | 1997 Oldsmobile LSS
My blowermotor fuses keep blowing withih 5 min. of putting them in. We have changed the blowermotor and the resister. What else can it be
check the switch if it's not making a good conection it will cause a high amp draw and blow the fuse after it gets hot
Nov 20, 2009 | 2002 Ford Explorer
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
