Question about Samsung SMN7502 Galaxy Note 3 Neo Duos
Doesn't Work It created a profile but will not switch. It says may take up to 5 minutes, I waited 47 minutes and all it did was sit there and spin. I'm using a Note 3.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
What app are you using?
Posted on Dec 01, 2014
  • Daniel Cardenas
    Daniel Cardenas Dec 01, 2014
Reset passlock code
Is your Impala a 2000, 2001, or 2002? This seems to be a common problem in those model years...much like its predecessor the GM VATS (Vehicle Anti-Theft System). While the VATS had a permanent (albeit unapproved) solution, no suck workaround appears to be available for the Passlock system. Some websites offer a correction "module" that looks to be a hit-or-miss solution. I did find the following procedure on a forum, and it seems to be reliable. Here goes:
If your car has been sitting while you were at work or home or in the store, and you are coming out to leave, follow steps 1-6.
If you just had the SECURITY SYSTEM lock you out of the ignition system, you will have to wait the 10 minutes for it to reset and allow the ignition control module to interact with the system. Once the 10 minutes have passed from the ACTIVE SECURITY STATUS, follow steps 1-6. Do not try to shortcut this as it wont work.
If it is raining, you can close your door, just not all the way. Close it all the way and open the door latch without pushing the door open. This will keep you dry.
+++++STEPS+++++ 1.) OPEN YOUR DRIVERS DOOR AND SIT DOWN. 2.) PLACE KEY IN IGNITION, WAIT FOR CHIME. (3 seconds is what I usually wait) 3.) TURN IGNITION 1 CLICK RIGHT (TO THE ACC POSITION) AND STOP! Do not continue to ON and START yet. WAIT ATLEAST 5 SECONDS 4.) AFTER 5 seconds has passed, TURN KEY TO ON and STOP, DO NOT CONTINUE TO START YET! 5.) WAIT AND WATCH. With your drivers door open, here is what you will see and hear = Your notification will signal DOOR ADJAR, then the BATTERY light, then the SECURITY light, during which you will hear the chime sound as if you just started the car. 6.) AFTER YOU SEE THE SECURITY light switch back to DOOR ADJAR or Battery, and after the CHIME has stopped, you can turn the key to start and voila!
It has worked every time for me and 5 of my friends. This whole process takes about 20-30 seconds, but it sure as hell beats 30 minutes, as GM refuses to compensate my time lost to their vehicle\'s design flaws.
RECAP: 1.) Open driver door, sit down 2.) Insert key in ignition, wait for chime 3.) Once chime starts wait 3 seconds 4.) Turn key to ACC position WAIT atleast 5 seconds 5.) After 5 seconds turn key to the ON postion and wait for the security light to switch back to Battery or DOOR adjar, and the chime to stop (Do not try to START if the chime is still sounding) 6.) Once chime stops and Security light has passed, You may now complete the turn to START and it will start.
Note: This is not a permanent workaround, but it will buy you some time, I can almost guarantee it will work for most if not all people, almost all the time.
Oct 11, 2013 | Chevrolet Impala Cars & Trucks
My GE profile Convention Microwave model JVM1790SK01 dial is loose and does not work. How can this be fixed?
see the information and use the common sense: God bless you
. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
Sep 07, 2012 | Microwave Ovens
Green light blinking very fadley pc will not turn on
Sounds like you might have a partial power supply failure. Try unplugging the power supply from everything. Ther should be a switch on the back that is red and says something like 115/220 just flip that switch over to 220 and wait 5 minutes then switch it back to 115 and replug everything in and then try it. If it doesn't work then unplug everything again and let it sit for about 30 minutes (this resets the power supply) and reconnect the wires and if that doesn't work try getting a new power supply. In partial PCB (Power Supply Board) failures the problem is that trere isn't enough power going to the system to start up so sometimes resetting the PCB will fix it temporary. You should get a new one anyway. that one will fail completely soon. Good luck!
Mar 15, 2012 | Dell Computers & Internet
Replaced batteries now i have black screen
Check the contrast levels (2nd+Down). If that doesn't work take out the 4 aaa's and set the calculator down and wait for a minute or so (for the power to drain from the capacitors) replace them and check if it worked. If that doesn't work, take out all batteries, including the small watch battery and leave it sit for a minute or so, replace them and check. Finally you can try calling Ti-Cares (1-800-842-2737) they're very helpful.
Aug 06, 2011 | Texas Instruments TI-83 Plus Calculator
Purchased GE Profile dual fuel range 6 months ago. Clock has always run fast and today the entire touchpad control went dead. The oven light works as does the gas burners. I am not sure if I inadvertly...
Unplug the unit and wait 2 FULL MINUTES before plugging it back in. That will reset the circuit board and you should be good to go. If it doesn't work, my bad!!!!!!
-AGK
Apr 17, 2011 | GE Profile JGSP44 Dual Fuel (Electric and...
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
Water goes into machine but woun't spin after about 5 minutes th 5 far right lights start to blink wait a minute hit start button everything works fine. kenmore front load 5 years old
This could be a few problems - from the timer to a pressure switch - to a bad lid switch.
Please reply with the exact model # for a more exact answer.
Thanks!!
Mar 22, 2010 | Kenmore Washing Machines
P26 on screen of Konica 1216 copier. Can you help - step by step please
the right solution to P26 error reset is mode 47 --> and pressing 5 and 1 key's....you must to wait 2 to 5 min,.for developer initialization....
Oct 21, 2009 | Ricoh Aficio 1013F Copier
New ignition switch now car security system locked
ok here you go
make sure the battery is fully charged befor starting
turn ignition to run
attempt to start once then release the key in the run position
let vehicle sit with the key on for ten minutes
the security light should turn off
turn igniton switch off
wait 5 seconds
turn key to run position
let vehicle sit for 10 minutes
turn key off
wait 5 seconds
let vehicle sit for ten minutes
turn key off
wait more than 6 seconds
and start engine
Jun 14, 2009 | 2001 Chevrolet Monte Carlo
Samsung SMN7502 Galaxy Note 3 Neo Duos Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
