Brinks 44-1070. It is anot alarm clock with a plug
Brinks 44-1070. It is anot alarm clock with a plug in the back to plug a lamp into. It has an on/off and a dimmer button. Has no instructions. Can't get it to work.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
Google it. I bet anything you can find how to set it up by googling it
Posted on Nov 12, 2014
2 Suggested Answers
  • 814 Answers
SOURCE: Emerson Smartset Clock Radio setting for everyday alarm
You will need to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio and remove the internal battery (CR2430). Let the Clock/Radio set without any power source for at least 2 hours. Then put the internal battery back in the Clock/Radio and plug it in to the a/c outlet. Test to see if the Clock/Radio functions have returned to normal. If the function have not returned to normal, you will need to replace the internal battery. Then let the Clock/Radio again set with out power for a period of at least 2 hours. after a 2 hour period, put the new battery in the Clock/Radio and Plug it into the a/c outlet. Test the functions to see if the microprocessor has reset to normal operation. If you are still having a problem with the Clock/Radio's operations , you will have to give the Emerson customer support a call. The Telephone number for the Customer support is 1-800-898-9020. You can call them between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you fix the problem with the alarm in the Clock/Radio.
Posted on Jun 13, 2009
I can't fix the trimmer brinks 42-1006 .. Please
see in the back of the alarm clock you will see the alarm sigh
Nov 28, 2012 | Hardware & Accessories
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    Please assist me in setting this light timer. brinks-42-1020
    Instructions for Brinks 42-1020
    1) There are plastic segments located around outer edge of timer dial.
    These segments divide each hour into 15 minute periods.
    Push segments down like a piano key for all hours you want timer ON-or-OFF
    2) Push switch to Auto ON -or- Timer
    3) Turn lamp ON, make sure bulb is working, plug lamp into timer.
    4) Plug timer into wall.
    Manually rotate timer dial clockwise to observe light turning on-off.
    This action will say if light is ON when segments are up or down.
    5) Unplug timer, and set segments for times you want lamp to turn on-off.
    6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial
    7) Plug timer back into outlet. Dial rotates as time passes, segments click a switch that turns lamp on-and-off.
    Add a comment for more free help, or to further clarify this free answer.
    Also take advantage of fixya phone service.
    For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
    Jan 11, 2011 | Hampton Technologies Brinks Timer
    I need a manual for the Timex T229B clock radio. I can't even figure out how to turn off the alarm. Please tell me how I can find one - preferably free. Thanks, Patty.
    I can't find the Timex T229B on the Timex support site. However, the T228B may be similar. To turn off the alarm completely, there is a switch on the left side that must be set to Off. The switch is labeled Alarm on one side and Radio on the other. In between are 4 positions - from front to back, Radio, Buzz, Off and On. When in the Off position the alarm indicator symbol will not be lit at the top left of the display (it looks a bit like a bell). The dimmer switch is in front of this Alarm/Radio switch on this side of the clock.
    To turn off the alarm and reset it for the next day, press the Alarm Set/Reset button to the right of the hour and minute buttons. The Snooze button is the large button to the left of the hour and minute buttons.
    Timex alarm clock and clock radio manuals are available here: http://www.timexaudio.com/product_manuals.asp .
    I hope this helps.
    Dec 23, 2010 | Timex T229B Clock Radio
    Instructions to 'science museum' radio controlled alarm clock
    press the alarm button (so the alarm time is on the screen) then the + button. do the same to deactivate the alarm.
    it took me forever to work this out after losing my instructions, feel a bit of an idiot now it seems so simple
    Jan 05, 2010 | La Crosse Radio Controlled Atomic Clock
    How to make the digits dimmer?
    You can do this by using the snooze buttons,
    Any idea how to reset the clock?
    Jul 19, 2009 | Altec Lansing M302 moondance HOME Alarm...
    Bratz talking alarm clock
    I purchased a Bratz talk back alarm clock for my daughter, however, she threw away the instructions.
    Can you tell me how to work the clock to hear it talk back or to activate the talk back voices.
    May 07, 2008 | MGA Entertainment Bratz Plugged In Talk...
    Digital clock radio
    Nov 12, 2007 | H.H. Scott SCR120 Clock Radio
    81 people viewed this question
     Grubhead
    Grubhead
