<!-- from fixya rte -->How can reset sharp 5618s copier machine - Office Equipment & Supplies
5 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: sharp ar5320 developer reset code
The developer doesn't have a reset code.  It uses a calibration program instead with the reset integrated into it.
Even though the copy quality is fine for now, it can change in the next few days.  You should order some developer.
Posted on Sep 18, 2008
  • 126 Answers
SOURCE: what is the code to reset the Sharp AL 1631 copier
Sharp - How to reset code
To enter service mode press thesekeys: orange C button,Interrupt, 0, Interrupt. The screen goes black when you have done itcorrectly. It may take a few tries – must be done in certain time.
To clear the maintenance indication (service man): press 20, start,1, start (the display will start to flash when entered correctly).Power off/on to make the copier dude go away. Good Luck!
Posted on Feb 01, 2009
  • 990 Answers
SOURCE: Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
Posted on May 30, 2009
  • 351 Answers
SOURCE: Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Posted on Dec 19, 2014
Sharp ar 5618s f2 error
check the toner or drum cart. if third party replace with OEM
Jul 22, 2015 | Sharp Office Equipment & Supplies
Code for develpoer in sharp ar-5618s
to obtain developer code you should contact the manufacturer
Jun 04, 2015 | Sharp Office Equipment & Supplies
Total counter reset program for sharp ar 5618
Can not be done. people then would reset the counters on old machines and sell them as new
May 16, 2015 | Sharp AR-5320 Black and White Copier
Why is my Sharp ar-5618s showing a green light on the mainboard?
green light on the main board normally mean good!!!! why looking at the main board???
Apr 07, 2015 | Sharp Office Equipment & Supplies
Dec 19, 2014 | Sharp Office Equipment & Supplies
"SHARP COPIER AR-5618S, A NEW COPIER, TONER EMPTY, I REFILLED IT, BUT TRIANGLE RED LIGHT IS..."
Your problem is that you should not use refilled toner in you sharp copier but if you chose so you have to change also the chip in the end of the toner it will work fine
Jan 30, 2014 | Office Equipment & Supplies
SHARP COPIER AR-5618S....TONER EMPTY. IT REFILLED. BUT EMPTY SIGNAL ALSO NOW.PLS SAY ITS RESET CODE
No reset code ;once you replace with new toner it should be ok.
Do not switch off machine when replacing.
Jan 30, 2014 | Sharp Office Equipment & Supplies
Sharp AR 5618S Error F2
Hope this help.
Hold down the copy start button
You will get F2 flash then 2 numbers will flash
http://www.manualslib.com/manual/902246/Sharp-Ar-5618.html?page=55#manual
Jul 06, 2012 | Sharp Office Equipment & Supplies
Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
Jan 20, 2010 | Sharp AR-M208N Copier
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
23 people viewed this question
jasbo
jasbo
