Question about HP laserjet 2055 series 500 sheet paper tray ce464a new ce464a
How to fix error printer 2055 laser jet has massege output bin is full
    Habit-Forming:
  • 91 Answers
There is a small flag sensor in the output tray over the roller that deliver the printed paper , its not return down after paper get out. so the the printer scene the tray is full , check it may lost if not try to lubricate the support pour it hasn't spring it move to its weight. or it may
Posted on Nov 13, 2014
pdouglasss
  • 125 Answers
SOURCE: error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
13.10 PAPER JAM The event log message for a paper-delay jam in the duplexer is 13.10.
1. Check the duplexer and the rear area of the printer for obstructions or damage.
2. Check PS1701 and PS1703 in the duplexer for correct operation. Replace the
duplexer if a sensor is defective.
Hope this helps
Posted on May 24, 2009
  • 12 Answers
SOURCE: Error 49 4CO2 Service Error on a HP Laser Jet
This is related to the JetDirect Card and the specific print job attempting to print. If JetDirect is 615 or lower slide out JetDirect card and power cycle printer once it comes up o.k power down and
slide JetDirect card back in once the printer is back up look on the display for processing job which may take 5 minutes but it is the offending job trying to print again as it is still in the print que. If you are quick enough you can hit cancel on the display panel to cancel the corrupt printjob and if you are successful then the other print jobs stacked behind it should start printing away with no problem. Hp blames the 49 error on a plethora of problems though mine are usually related to documents using different versions of Adobe and also PowerPoint printjobs that are excessively large as the print spooler cannot handle them but it is always a corrupt print job and once that is cleared no problem. Occasionaly replacing the JetDirect card is required to solve the issue. With the 620 Jetdirect card no need to remove it just unplug the network cable same procedure as above.
Posted on Nov 22, 2009
  • 224 Answers
SOURCE: Getting the error on my HP 4345mfp - TOP OUTPUT
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Posted on Mar 31, 2010
  • 79 Answers
SOURCE: HP 4200 Laser Jet Printer Error Code 82.0180
The error message "83.0180" shows that an EIO error has occured.
Perform the following workaround and see whether the issue still persist.
1. Ensure that the printer is connected directly to the wall outlet.
2. Turn off the printer and then power on and see whether the issue persist.
3. Reseat the Jetdirect card and see whether the issue still persist.
4. Reseat the jetdirect card on a different slot and see whether the issue still persist.
5. Remove all the accessories from the printer and then power on the printer. See whether the issue still persist. If the issue does not persist, add on the accessories onee by one.
6. Power on the printer and check whether the issue persist, each time an accessories are added.
7. Swap the Jet direct card with a known good jet direct card and see whether the issue still persist.
8. Perform a cold reset and see whether the issue still persist.
To do a Cold Reset:
1. Remove all cables.
2. Press & hold the Test button while applying power & continue to hold it for 10 seconds, then release it for 10 seconds, then unplug it again.
3. Connect all cables & power it back up.
4. Wait 2 minutes for discovery & DHCP. If desired, change the DHCP & address settings.
Posted on May 07, 2010
  • 6 Answers
SOURCE: HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Posted on Jul 20, 2010
Output bin is full for hp laserjet 2055
Check the flag that hangs down as the paper is exiting printer.... sometimes the flag gets stuck in the up position..(causing the printer to think there's a big stack of paper needed to be taken off the machine...found this from another fixya member.
Dec 07, 2016 | HP Office Equipment & Supplies
Hp laser jet printer 2055 problem output bin in full?
If you have already removed the paper from the output bin, check the delivery flaps to make sure they move freely. If they do, remove the top and make sure the sensor flag isn't broken and that the sensor is connected and undamaged. If it is connected and undamaged, check connector J213 on the engine controller is seated correctly. If it is, you probably need to replace the output bin sensor. See attached video
Nov 18, 2015 | HP LaserJet Office Equipment & Supplies
Hp 9050 laser jet stacker error
Probably just a bad sensor or dirty sensor causing the issue.
Stacker or stacker/stapler output bins
For the 3,000-sheet stacker or 3,000-sheet stacker/stapler, the output bins are the upper bin (face-up) and the lower bin (face-down).
The upper bin (face-up) is the top bin on the stacker or stacker/stapler. This bin holds up to 100 sheets of paper in face-up order as they exit the printer. A sensor causes the product to stop when the bin is full. Product operation continues when you empty or reduce the amount of paper in the bin.
Lower bin (face-down) is the lower bin on the stacker or stacker/stapler. This bin holds up to 500 sheets of paper and can stack or staple jobs. This bin is the default output bin.
Aug 19, 2014 | HP Stacker For LaserJet 9040/9050/9500...
Standard bin full
This error is cause by either having your output paper bin full of paper or the flag sensor out of alignment where the paper comes out of the top. Look at the top f the printer where the paper comes out and you should see a black plastic sensor flag, it should move freely. If it is stuck remove the top cover above it and try to free it so it can move. Below is a picture of the printer with the output sensor flag circled.
Feb 02, 2013 | Lexmark T632 Laser Printer
Output bin full error flag broke
You need to replace the Output Bin Flag. Please call our Technical Support Hotline on 1-800-539-6275 or contact an Authorized Service Provider near to you (click this link: http://bit.ly/UeQhSB).
Jul 07, 2012 | Lexmark C762 Laser Printer
Laserjet 2055 install black cartridge error
hello for all my dear the problem in hp lj 2055 install black cartridge error massege here the solve iam engineer in hp service center and i meet that problem in my daily work the problem in dc control must t replaced sure 100%
May 30, 2012 | HP P2055DN LaserJet Monochrome Printer
Output bin is full error on hp laserjet 2055
check the flag that hangs down as the paper is exiting printer.... sometimes the flag gets stuck in the up position..(causing the printer to think there's a big stack of paper needed to be taken off the machine
Feb 05, 2010 | Minolta QMS PagePro 9100 Laser Printer
Error printer bin full
This is an error when it senses there are too many pages that have been printed and are sitting in the bin.
Take a close look at the flaps hanging out the exit for the printer. They should move up and down freely. If one of them is stuck up, broken or dislodged, you'll get the bin full error. The flaps on the other end (side you can't see) have little flags that sweep between photo sensors and tell the printer in the tray is full and if paper has exited the printer into the tray
Nov 05, 2009 | Minolta QMS PagePro 9100 Laser Printer
Standard Output Bin Full
Check near where the paper comes out for a little plastic flag that can move up or down. If it's the model I'm thinking of that has that, It's possible it has stuck up, making the printer think the paper bin is full. If so, you should be able to just flick it down and it'll be alright.
If not, well, maybe someone else can help you out, this is just the first thing I thought of.
Mar 03, 2008 | Minolta QMS PagePro 9100 Laser Printer
HP laserjet 2055 series 500 sheet paper tray ce464a new ce464a Logo
326 people viewed this question
Seeker5211
Seeker5211
