Whirlpool AW041608 Washer not functioning. Power supply is good, but no lights on
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
Power supply???
Are you referring to receptacle it's cord is plugged into?
Or did you open it and check for power where the washers power cord terminates inside the washer?
Posted on Nov 12, 2014
I have a Whirlpool Duet Washer and I keep getting an error code "FL". Can someone please tell me what it means and how do I fix it?
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. Press the power button, and the washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Dec 15, 2016 | Whirlpool Washing Machines
Whirlpool washer with error code F08 E01, what does it mean?
Check your water supply is connected and turned on as this is a water supply error. Press on/off button to reset and then press on/off again. should clear if water supply is good.
Feb 06, 2015 | Whirlpool WFW9351Y Duet 3.5 cu. ft. HE...
Location of fuse in Intelligent Module
Fuse panel B contains fuses that supply power to washer functions. 25A fuses 34 and 33 and 30A fuse 32 supply power to the vehicle electrical system control module. 30A fuse 38 supplies power to the wiper motor control module. 5A fuse 19 supplies power to the rain/light recognition sensor. 30A fuse 36 supplies power to the headlight washer relay. 10A fuse 15 supplies power to the instrument cluster control module for washer fluid level sensing. 10A fuse 13 supplies power to the windshield wiper/washer switch in the steering column electronic systems control module. In addition, 5A fuse 20 supplies power to the washer nozzle heaters. Troubleshooting all this could lead to an answer.
Jan 28, 2014 | 2007 Audi A6
We just had a power outage.... washer will not turn back on.. door will not open... cannot get any of the lights to come on...power, start, cancel nothing.... Thank you Lisa
Have you checked the washer's supply socket? Test with another item such as a kettle. If not OK then check the breakers/fuses in the mains supply box. If they are all OK is there a fuse in the washer plug? If so check that. If you have no way of checking it, change it for another one ;-0)
If all these fail I fear it means a call for an engineer, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool calypso washer just quit working no codes no power just dead. GVW9959KQ2
Won't Power Up
  • 120VAC electrical supply.
Check voltage supply to washer.
  • Open AC cord.
Check for voltage at the power cord connection to the line filter.
  • Line filter open.
Check voltage into and out of line filter.
  • Machine control board open.
With the washer off but connected to the AC outlet, measure the AC voltage between Pins 4 and 2 at connector P16.
Dec 23, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Power is on, still will not start
Too many clothes
washer door not opened between washes
low power/extention cord
kinked hose
Door not shut tightly
hoses connected backwards
inlet screens clogged
circuit breaker tripped
unbalanced load
excessive suds
wrong detergent
Repair Manual
Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
No water goig in
Make sure your supply is open. Try rotating the timer clockwise 180 degrees and try again. It could also be a bad water valve solenoid. Make sure power supply is good.
Jul 01, 2009 | Whirlpool WVP9000SB Front Load Stacked...
Whirlpool GVW9959k02 Washer with an error code of 44 and all the normal lights are lite. Will not turn off or cancel out.
Reset all setting to factory defaults.
Also check your power supply is good.
Turn off it for some time then check.
Jun 25, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Wont start
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam washer has no power!
call whirlpool, sounds as if you have a faulty electronic control board( power supply board) warranty issue, non need for you to get involved with the repairing of this
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
