Question about Cameras
How to program a king esp 230 digital thermostat
    Master:
  • 876 Answers
How do I find out what the value of my Weather King central A/C is worth?
the question you asked is too vague and you have 2 refrigrants listed as well,, what valve
Oct 16, 2014 | Heating & Cooling
We have a weather king central air unit mod# WAKA-030JAZ. ser#5339 mo6959417. volts 208/230. compressor rla 13 5/13.5. outdoor fan motor f.l.a.9. mfd 02/05. hertz 60. l.r.a.76. hp1/6 min supply...
I would bet the outside units contactor is bad. This is the device where the two thermostat wire connect outside. If this is pulling in/out as you turn the stat on/off then it is working. I just fixed one yesterday with the same symptoms and found the start capacitors were bad. If they are bulged at the top or bottom then they are bad. Good luck.
Jun 19, 2011 | Weather King Heating & Cooling
Have had ice and snow here in ATL. Today heat in Weather King RCBA 3765 GG17 would not come on. Checked Breakers, A/C breaker was tripped. Reset breaker, checked for ice in condenser (W/K 10PJA 3701),...
Try R to G instead. The red is the 24v side. Greeen is the blower. You should also have 24v ac between r and c (brown or black) at the air handler. You can check at the condenser for power also. Turn the unit on at the thermostat and go outside to check thermostat wires between y and common (probably brown or black). Possible a transformer went bad. If it were a problem with the air handler or the condenser, one would run and the other wouldnt. In this case neither run so you have to look at what controls both. I say transformer or thermostat. If you find 24v in either place, its not the transformer.
Jan 18, 2011 | Weather King 10PJA2501AH Air Conditioner
Can I change the color of pictures to black and white? If so, how?
The FE-230 doesn't have a black&white mode. However, just about any photo editing program will give you the capability of converting color pictures to black&white. Doing so on a computer also gives you much more control over things like brightness and color.
Dec 23, 2010 | Olympus FE-230 Digital Camera
Installing 1 1/2 ton Weatherking Heatpump and ADP WAK351807P2 air handler 1 /1/2 with 7.5KW back up heat kit. Can't seem to get the thermostat hooked correctly. I understand the Weather King product...
O energizes the reversing valve when the thermostat is set for COOL. B energizes the reversing valve when the thermostat is set for HEAT.
The O/B is usually a orange or black wire.
You can't hurt anything if you choose O or B incorrectly. Hook one of them up and run the unit. If set for COOL and the unit runs cool inside it is correct. If set for COOL and the unit runs warm inside it is not correct.
If the inside temp is opposite from your setting change the wire to the other terminal.
Remember to disconnect power from the air handler when changing thermostat wires.
The defrost control board on the outside unit should be marked correctly for O or B.
Your thermostat may have a slide switch rather than a separate terminal.
Oct 30, 2009 | Weather King 10AJA6001AH Air Conditioner
Deleated photos that I want. How can I retreive
If the photos are on a memory card and you haven't done anything to the card since you deleted the photos, you may be able to recover at least some of the photos. Do a Google search for "data recovery software" and select a program for you computer and operating system. Put the card into a card reader attached to your computer and run the program.
Jun 17, 2009 | Olympus FE-230 Digital Camera
Cameras Logo
63 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
