My central electric heater work to poorly - Heating & Cooling
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
Change the filter, then before installing the new filter turn the unit off and clean the elements real good.
Posted on Nov 12, 2014
Pressure gauge keeps going down when the central heating goes off ,it is fine when it is on the pressure stays high
Is your central heating unit a heatpump w/ electric heat or natural /propane gas ? And what is the water heater, gas or electric ?
Dec 07, 2015 | Water Heaters
My central heating works fine but the tap water is just warm at best. You certainly cannot enjoy a bath!
Are we talking about a boiler situation? You mention "central heating" and tap water.
If it's a water heater separate from the furnace then I would say a element going bad, assuming it's a electric water heater. If it's a single boiler unit, I would have to say call a service tech.
In either case, you will need to post more information regarding the equipment before a reliable answer can be given.
Nov 01, 2015 | Water Water Heaters
In the electric heater is posible that some elements get burn and make the heater work poorly
By poorly do you mean the fan doesn't blow? Does the heater not get hot? Sometimes we just need tho clean the heater, you know get rid of the dust. Some heater also have a filter on the back..if this is dirty the heater won't pout out as much heat.
Nov 13, 2014 | Water Heaters
Have oil heater that we had serviced yesterday. Heater stays at temperature but circulating pump will not send heat to upstairs radiators. (heater in basement) Any advice?
Try putting in central heat and air in your house don't rely on some basement heater then you will have a basement heater for when it get cold
Dec 03, 2013 | Lakewood Oil-Filled Electric Radiator...
Central post cracking and spliting
If it's electrically heated, disconnect the mullion heater. If it's mechanically heated, from the refrigeration lines, clean the condenser and check the fan is working. It is getting too hot!
Aug 06, 2012 | Thermador KBUDT4270A Side by Side...
Connect my 24 milivolt gas (between the studs) wall furnace ( in my hall) to my thermostat that operates my electric heat central unit. problem: to sync both units to give home more balance ( hall is...
the first problem is you need a milli-volt t-stat and your central has a 24volt t-stat if you connect the 2 it will fry the controlls in the wall heater the second problem is t-stat location if the wall heater is near the central heats t-stat it will shut off the central to soon . maybe relocate wall unit to coldest room ?
Nov 16, 2010 | Honeywell Heating & Cooling
Thermostat not firing central heating
the stat works using a bi metalic strip so that click you here is making a contact and telling the boiler to call for heating so if you getting no click you need a new room stat. Replace with same model and note the wiring most stats only use 2/3 wires depending on system
Dec 08, 2008 | Dayton Electric Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
