Question about Briggs & Stratton Garden
Do you have to prime a fuel pump after it has been rebuilt
Briggs 42e707-2631-e1
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 18 Answers
When you put a new fuel pump on whatever type mower you are working on,yes its good to prime it a little so that your not cranking the juice out of your battery and easier on starter.when you prime it ,myself I put the new fuel pump on,and I pull the plug out and put a little fuel in cylinder head so when it fires it pump the fuel up faster to your carb! good luck!
Posted on Nov 12, 2014
I have rebuilt the carburetor on a 16HP Briggs and Stratton Vagaurd. But can not get gas to engine, it runs when I pour gas in the carburator, What could be the issue.
Have you checked to make sure the float level is set correctly, or that the float isn't sticking, not allowing fuel in?
Are you pouring fuel into the top of the carby, or syphoning it in via the fuel inlet?
Jan 30, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Have 22HP BS V-Twin in a 2010 Husqvarna rider w/25 total hours. Recently won't cold start without priminig. It will crank and crank cold til the battery runs down. A shot of starting fluid and it runs...
nearly all petrol mower engines need to have the 'choke' engaged to start from cold. This enriches the fuel mixture, and is similar to priming. If there is a prime 'button' then you will probably have to use this all the time. This is normal.
However, you should check with your dealer to see if this is an unusual situation.
Aug 27, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Engine runs for a short time then dies, replaced plugs, air filter, in line gas filter, and rebuilt fuel pump
I had a B&S lawn mower engine that did this unless I kept pushing on the prime button and I found I had a Cracked primer rubber bulb. Maybe you have something similar or another type or carb problem.
Jul 28, 2011 | Briggs & Stratton Tools & Hardware -...
Will only run until primed fuel is burnt - 2 seconds or so
Dave,
I am having the exact same problem. Did you find a fix?
Don
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
It just quict. if i prime motor it will run short...
if it has fuel pump unhook line from pump and gravity feed carburetor if it runs the pump is bad
May 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Won't stay running
I took the carb apart and found that it needed rebuilt, I installed the new carb and fuel pump kit and it runs great again.
Apr 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My friend has a 18.5 briggs stratton v- twin that
The engine fuel needs to be primed into the carburator and the choke set.
Sep 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
