My element keep showing the scan for channels info..
It will come on but that's about it...
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Sounds like main system control memory IC fault. Contact any service technician. http://electronicshelponline.blogspot.com/
Posted on Nov 12, 2014
How to reset channel auto scan.After I finish channel scan,message pops up stating PLEASE RUN CHANNEL AUTO SCAN,
If when You scan, and you don't get at least one channel, it will keep showing You this message! look at screen it will show new channels! if no new channels check to make sure your coax is hooked up good, also make sure you are using right setting if outside antenna, select antenna, if cable select cable for your source!
Nov 03, 2016 | Televison & Video
I have an Element ELEFT502 50 HD Digital tv. I am trying to connect my cable line to the TV but cannot get the past the auto scan screen
put the co axel cable in the back , bypass this tv programming stuff put your tv on channel 3 or 4 and use the cable remote , no tv channels just cable
Feb 26, 2015 | Element Televison & Video
How to do a channel setup on a 32" element TV model no. ELEFW328 HDMI .
somehwere in the main menu there should be auto scan. look for that then do it depends on what type of input you set in also Cable,sat, or antenna
Feb 10, 2015 | Element Televison & Video
My element tv will not show above channel 27
did you set it to cable an then do a channel scan
Aug 17, 2014 | Element Electronics Televison & Video
Element tv keeps saying please run auto scan
May be there are some out of frequency channels. Go to searching menu option and use manual tuning for personally. Auto scan for all channels.
May 11, 2014 | Element Televison & Video
Tv setup - cannot get past auto channel
Connect the TV to the Comcast box using an HDMI cable, then set input on the TV to HDMI - that's all. You then select channels on the Comcast box , not the TV (although the TV remote can be programmed to change channels on the cable box)>
Jan 27, 2014 | Element Televison & Video
I need to do a channel scan on my tv to get the service working but i cannot find channel scan options on the menu. Where is the channel scan option on the sharp LC-32SB24?
During power up and first time use, there should have been an option for channel scanning as the initial setup wizard began.
Alternatively, there should be a way to navigate to the channel scanning menu by selecting, Menu>TV>Auto Channel Search. I couldn't get the exact info from the model you listed, but I gathered this info from a similar owner's manual (lc-32sb28ut) from the Sharp webpage: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Hope this helps.
Oct 17, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Element Electronics FLX2211B 22 in. LCD TV will reset every time
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me.
WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels.
WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels.
These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels.
Best of luck.
May 02, 2009 | Element Electronics FLX2211B 22 in. LCD TV
I have to keep resetting the channels or unchecking the skip option on my Element FLX32FHDH tv. Is there a way where I can set this and not have to keep resetting it?
My Element FLX32FHDH seems to lose it's channel list if it is off for 6-8 hours. The channel up and down buttons don't work, and I can't key in a channel. In my case, if I hit "enter" before any other key on the remote, after turning on the set, the channel list menu will appear, with all the missing scanned channels showing. Pick any one, and the set jumps to that channel, and all functions are restored. The stored channels were not lost, but some sort of access flag or variable has been corrupted and the chip won't access the database. Not a fix, but potentially a work-around for you.
Mar 04, 2009 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
