Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
How do i take off top of dryer to change belt
    Sergeant:
  • 198 Answers
Unplug the dryer! My dryer top is hinged in the back, so I just gently pry up the front of the top after unscrewing the lint trap. Then there are two screws near the top of the front panel holding the front panel to the sides. Remove screws, then the front panel lifts up. The drum will drop down. You can now remove the drum since the belt is broken. Check the back rollers, clean the motor, clean out the inside of frame, replace the belt - making sure it is fed through the idler properly, install the drum- working the belt around the drum, making sure the belt is not twisted and in the correct position on the drum. Reinstall the front panel, making sure the drum is seated properly on the back panel and on the front panel, now you can lower the top and have at it. Your dryer may be alittle bit different but a dryer is still a dryer.
Posted on Nov 12, 2014
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Tip
My dryer drum will not turn...."how to change your dryer belt"
There are many styles and different models of dryers but the one thing they all have in common is the dryer has a belt that turns the drum.In the procedure below we will show you how to take apart your dryer,change your belt,and show you the correct threading of your belt. Here is a typical Kenmore dryer idler pulley(it has a plastic wheel on it) motor/pulley (the pulley is attached to the backside of the motor) and the belt configuration.Note the picture below.
Each different model dryer also has a different lint trap location. This location will have a bearing on how your dryer is taken apart and how to change your belt.
Note the location of your lint trap and choose the correct video on how to take your dryer apart. There are two different locations,on top,and in the door.
This video will show you how to take apart your dryer and change your belt if the lint trap is on top of your dryerhttp://www.youtube.com/watch?v=CFnXwmUb4f4
lint trap on top
This video will show you how to take apart your dryer and change your belt if the lint trap is inside of your door. http://www.youtube.com/watch?v=rtATa0a28bE
lint trap in door
This video will show you how to take your dryer apart and change your belt with the control panel in the front side panel rhttp://www.youtube.com/watch?v=zpUqCrLaI7g
control panel in front
This video will show you how to take apart your Maytag L shaped dryer and change your belt.
http://www.repairclinic.com/PartDetail/Belt-Drive/1246110?modelNumber=LDE8424ACE#repairHelpVideoTabs
L shaped dryer
If you happen to run into an issue with your belt and pulley configuration all the diagrams are here click on the linkhttp://www.repairclinic.com/Dryer-Belt-Diagrams
If this has helped you please consider giving us a 4 thumbs up on our rating.This procedure has saved you a minimum of $125.00
Thanks in Advance and Thank You for using Fixya!
on Mar 21, 2011 | Dryers
Change belt
Here is how to open the dryer to change the belt on the link below.
http://www.ehow.com/how_4841992_change-maytag-dryer-belt.html
Apr 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Changing dryer belt on maytag performa
Here is a link for both old-style and new-style Maytags.
At the top of the page you'll see the word "here" -- click on the appropriate one to get the belt-change procedure.
Charlie
http://www.applianceaid.com/maytag-dryers.html#belt
Aug 31, 2009 | Maytag Dryers
Belt Change on a DE313 Maytag Dryer
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Jul 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Changing belt on my dryer
I am not familiar with this particular dryer, but all electric dryers are designed so that the consumer can replace the belt. Open the access door ( the back, the top, or the removable panel at the bottom front) and the belt should be visible; a few minutes of study will show you what you need to do to change it.
Apr 22, 2009 | Candy CDV262 Dryer
Changing dryer belts. How do I open the dryer to change the belts? I think one of them are broken.
either the top pries up or you'll have 2 screws at the very bottom of the front panel from there you can remove the front panel but make sure you disconnect the door switch wires before yanking the front panel away
Mar 11, 2009 | Kenmore Elite HE4 Electric Dryer
Belt broke on Amana dryer
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Jan 29, 2009 | Amana ALE866SB Electric Dryer
REPLACING THE BELT
Hi thanks for the question. to replace the belt. open the door. screws on the inside, under top. remove screws . lift the top. 2 screws on the inside, of front panel. remove. pull front off. now replace the belt. thanks the appliance doc. please rate me. thanks
Oct 05, 2008 | GE DCSR483EA Electric Dryer
Fan Belt replacement
most dryer to chang the belt is take the top and the front cover off and the drum out . you will see the belt. but if you give me the m# of the dryer i can help moor.
Dec 28, 2007 | Dryers
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
89 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
