Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
<!-- from fixya rte -->How do u take off top of dryer - Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
The back panel has screws holding it to the top lid.
The top lid just pops up .
Posted on Nov 12, 2014
Drum hitting dryer top
Sounds like the bearing seals may be getting worn. You will need to open the top of the dryer and look for wear marks.
Oct 17, 2012 | Whirlpool LGB6300 Gas Dryer
HI I HAVE A DRYER MODEL DLG5988WM I WOULD TO KNOW HOW TO REMOVE THE FRONT PANEL
Step 1, remove dryer top: remove three phillips head screws from the back edge of dryers top.
stand in front of dryer and push back sharply about 2 inches on the dryer's top using the palms of your hands. Lift top up and off.
Step 2, remove control panel: remove phillips screws from back side of control panel corners and release clips along top edge of control panel, allowing panel to be taken off and set on top of dryer.
Step 3, remove front panel: Open door, remove phillips screws located at 4 and 8 O'clock positions at door opening. remove phillips head screws along fron panel's top edge. tilt panel forward and unplug light, door switch, and moisture sensor (at bottom of panel) and then set panel aside and out of your way.
Feb 03, 2011 | LG WD-3243RHD Front Load Washer / Dryer
How to replace on switch
  • Unplug the Frigidaire dryer from the wall outlet and move the dryer two feet from the rear wall.
  • Locate the screw on each end of the control console, securing the console to the dryer top. Remove the screws with a Phillips-head screwdriver. Lift the front of the control console and rotate the console toward the back of the dryer.
  • Remove the three hex head screws that secure the rear of the top panel to the dryer with a nut driver. The three screws will be on the top rear edge of the top panel.
  • Grab the top panel on each side and slide the panel forward. This will release the front spring clips that secure the front of the top panel to the dryer. Lift the top panel off the dryer and set the panel out of the way.
  • Dec 23, 2010 | Frigidaire Dryers
    How do I get to the gas coils?
    Remove top back of dryer that houses all the switches, remove screws in lint catcher area on top of dryer. Remove screws that are attached to clamps at back of dryer that hold top on. Top should now slid forward for you to remove. At the top of front cover on the backside of it, you need to remove screws that hold on the front cover. Then slide it up for removal. Hold drum or it will fall off. Gas coils are at bottom of dryer.
    Jun 10, 2010 | Whirlpool LGB6300 Gas Dryer
    One of the 3 arm or flip in dryer is very loose
    Remove the top of the dryer by removing the four screws in the back. the entire top should slide forward an inch allow you to lift and pivot the top off to the side. it will not come off entirely because of electrical wires. with that moved off to the side you should see the top of the drum. reach in the front door of the dryer and rotate the drum so that the loose blade is at the top. in that position you should be able to tighten the screws.
    Jun 26, 2009 | Maytag Neptune MDE5500AY Electric Dryer
    Lp conversion for LG dryer
    After removing the three screws which pass through the L bracket into the back of the dryer:
    Stand in front of the dryer and (using the palms of your hands) give the top a sharp push back on the dryer top at the left and right side of the top. The top should slide back 1 to 2 inches. Now lift the top off.
    If you post again with further questions, make sure to post under the model number you have. (you posted using a combo washer / dryer, and stated you are converting to LP, which combo units are not gas.)
    Apr 18, 2009 | LG WD-3243RHD Front Load Washer / Dryer
    Where do I find the heating element in my hotpoint dryer
    Heating element is behind the drum. Disconnect power. Use putty knife to release 2 spring clips holding top at front edge of dryer. Swing top back. Remove two screws holding dryer front to sides near open top. Swing dryer front to the side. (you don't have to disconnect the door switch wires) Remove plastic tub block at top center of opening. Release belt. Pull up on back of drum, then pull drum out through the open front of dryer.
    Sep 12, 2008 | Hotpoint NLL113EYWO Electric Dryer
    Stacking Frigidaire dryer on washer using stacking kit 5303937141
    You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
    Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
    DRYER HEATS ,BUT DOESN'T TURN
    FIRST UNPLUG UNIT!!
    Remove 2 screws by filter area on main top.
    Grab back of dryer and pull top forward while holding dryer in place with knees. Do this to pop up top on front left then front right. Remove 2 screws holding front panel 2 side panels. They are at top front of side panels, inside.
    Pull front panel out at top and pull up to remove front panel. Put belt around drum with grooved side toward drum.
    Nov 11, 2007 | Whirlpool LGR3624JQ Gas Dryer
    Roper gas dryer
    FIRST UNPLUG UNIT!!
    Nov 08, 2007 | AEG T57800 Electric Dryer
    Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
    43 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
