Question about Garden
Parts for a homelite little red xl chainsaw model no# ut10741
Loses prime and chainsaw runs than stops. someone on this god green earth has a bin full please help
  • 1,169 Answers
Not all of the parts are still available for this little saw. You will need to determined what exactly is causing the problem. Below you find a little info that should help about the parts.
The carburetor is not available; although, the rebuild kit is but you will use the carburetor make and model to find one. The is ignition coil is no longer available but there is an aftermarket that is.
Ignition Coil replaces Homelite 94711A 94711B 94711BS 94711CS
Parts List (Three model versions)
Model Search Results
Posted on Nov 12, 2014
dontbother10
  • 2220 Answers
SOURCE: homelite xl chainsaw revved up & quit and won't start now
I suspect you have a fuel delivery problem or a dirty carburetor. As a chain saw runs out of fuel they often revv slightly (running lean). HTH
Lou
Posted on Oct 07, 2009
SOURCE: homelite runs wide open all the time
intake boot under carb is probably bad, mine did the same thing and this was the problem. about a 6 or 7 dollar fix
Posted on Apr 11, 2009
SOURCE: chainsaw carburetion
Had a similar sounding problem with my stihl MS 250. After two years of heavy and frequent use (with minimal maintenance) it ran perfectly but after three years of little use with no maintenance it began to die if the revs were allowed to drop, ie it wouldn't idle. I hadn't been draining the tank when not in use so assumed a carb gunk problem. Can also be caused by an oily mix or old fuel.
Today I removed the old fuel and fuel filter and sprayed the tank and up the fuel line with carb cleaner. Then I removed the spark plug and filled the chamber with carb cleaner (use a straw to direct), I removed the air filter and sprayed carb cleaner in here too. I gently pulled the starter cord a few times to spread the carb cleaner. I left it for 1/2 hour while I had lunch.
I then rinsed out the fuel tank with fresh fuel, renewed the air filter, spark plug, fuel filter and fuel. I checked the H and L screws were in the right place (they were), before pulling on the starter a few times to prime / flood the chamber. I then removed the spark plug for 5 mins and had a cup of tea while the flooded chamber resolved / evaporated, then fired her up. It worked well all afternoon.
No need for any tricky or delicate stuff if you give this a go first is my advice. Cost only of spark plug, air and fuel filters, fresh 2" mix and a can of carb cleaner. Took less than an hour excluding interruptions. Saved a potentially expensive trip to the shop where I'd have been billed for these parts as a routine matter.
Posted on Jan 02, 2009
  • 597 Answers
SOURCE: old homelite XL chainsaw pumping bar oil into engine while runnin
Check that the oiler hole and the hole in the bar that it pumps into aren't clogged. The sawdust running under the chain and be deposited in the oiler hole in the bar until it plugs it solid. That will keep the oil from havintg a place to go and build up pressure.
Posted on Sep 23, 2009
Jim1969pa3
  • 152 Answers
SOURCE: Not running at full throttle
close to the carb you will find two tiny screws. They are labeled H and L. L sets the idle speed. H sets the max RPM. Hold the throttle wide open and turn the H screw. When you find the very top end, back it down some or it will be running too lean. That would make it run hot, and provides less lubrication. Could result in engine failure if you run it too lean.
Posted on Dec 23, 2009
WHERE CAN I FIND A MANUAL FOR THIS CHAIN SAW MODEL UT10753
You did not say who the manufacturer is of your chain saw. Is it made by Homelite?
Go to this website: http://www.manualsonline.com/ and type in your chain saw manufacture and model
Feb 21, 2016 | Garden
How do I start a Homelite little red XL
usually by pulling on the rope .after priming and choking with the kill switch turned to the run position .sometimes it helps to remove sparkplug and give it some fuel there and quickly put plug back in tight .
Nov 30, 2015 | Homelite Garden
Where can i get a replacement bar oil cap for a homelite xl chainsaw
http://www.ereplacementparts.com/homelite-chain-saw-parts-c-18807_21362.html?gclid=Cj0KEQjwpM2pBRChsZCzm_CU0t4BEiQAxDVFmuNsj0j4bpQsjOchGGvSh6DD6vZJIlALn6tjvNPauLIaAnUS8P8HAQ
Apr 19, 2015 | Homelite Garden
HAVE OLD HOMELITE SUPER XL AUTOMATIC NEED ON OFF SWITCH AND MAGNETO , WE HAVE NO SPARK AND HAVE DONE ALL THE OTHER THINGS . SER. NO 3G2550042 , THE NUMBER ABOVE THIS ONE IS , UT NO 10045-C
Is it this one? She has points.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/57a3b86d6acae4e188256c260048b728?OpenDocument
You may find parts for this grand old Lady here:
http://www.acresinternet.com/cscc.nsf/673d78ec01557aea88256b00005457e6/53fd90eee11e3fe8882572a300167f51?OpenDocument
Last chance try here (parts and guidance):
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
This is an international collection of chainsaw enthusiasts with a few 2-cycle mechanics and saw retailers thrown in. They are a good bunch and I am certain someone can help.
I did not see any Homelite (most makers have one) thread but did find this:
http://www.arboristsite.com/showthread.php?t=120583&highlight=xl+super
Be kind to her. HTH
Lou
Jan 18, 2010 | Homelite Garden
Runs well untill it gets hot. then cuts out
If it's the little xl model, it's probably the ignition coil breaking down when it gets hot and therefore it can't and won't be able to handle a load. Also, scarred pistons skirt or rings could also be some of the problem here. Make sure your mix for a Homelite saw is 40:1 not 50:1 like most saws are. Homelite seems to run better with a heavier oil mixture. Good luck.
Aug 02, 2009 | Garden
Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Jun 24, 2009 | Garden
Garden Logo
98 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
