Question about Garden
How do I remove pto shaft from chamberlain 3380 tractor
Have drained oil &undone bolts on pto housing
4 Suggested Answers
  • 6 Answers
SOURCE: drive pulley won't come off engine shaft
put the nut back on were it is even with the stud and hit with a hammer while pulling on the pulley
Posted on May 27, 2009
  • 6468 Answers
SOURCE: PTO NOT WORKING ON JD6300 CAB TRACTOR 4WD
check the safety switches
Posted on Apr 15, 2012
markellis808
  • 5 Answers
SOURCE: how do you replace a broken pto shaft in a 1979 2840 john deere
drill into it and use the biggest easy-out you can get your hands on.
Posted on Apr 16, 2012
1949 M farmall :pto will not engage
When you pull the rod does it fell like anything moves inside the tractor? If not, remove the four bolts holding the pto in the rear frame. Pull out the pto assembly and what you most likely will find is shift lever broke and not shifting the pipe sleeve to spline to the transmission shaft. Pull it out and look.
Nov 29, 2016 | Farmall Garden
PTO turns with mwoer shaft disengaged, blades turn when shaft is rotated by hand. Put shaft into PTO housing and the mower wont turn.
bad pto, 400 dollar to fix but a cheap option is to replace the pto switch in the dash first, is the pto switch clicking with the key in the ON position? if it is then it is the pto clutch bad
Jul 29, 2015 | Garden
Change seal for PTO kubota f3680
Remove the PTO shaft extension from the shaft put a drain pan under to catch the oil Tap a chisel or other tapered tool in behind the seal flange and work the seal out install a new seal an re-install oil up to full level
Jun 13, 2015 | Kubota Garden
How to remove rear diff from ve commodore?
loosen rear wheels, jack up rear so wheels are free, fit safety stands , drain oil, remove wheels, remove 4 bolts holding axle bearings. remove both axles, remove bolts from tail shaft at diff pinion flange , leave tail shaft in transmission housing or oil will leak out, remove bolts from diff housing, the diff center can now be removed.
Aug 28, 2014 | 1998 Holden VT Commodore
How do you remove a pto from a 1042 cubcadet
If bolt broke in crank shaft - you'll need to get some professional help to get it removed. The PTO slides down off the shaft - but you'll probably need a wheel puller to get it off. I had to clamp the upper and lower halves of the PTO together to pull them off as a unit.
Jun 02, 2014 | Cub Cadet Garden
Remove clutch
I'm assuming you're referring to the PTO clutch on the bottom of the engine shaft. There's a 5/8" bolt that goes up through the clutch into the shaft. Remove it, but then turn it back in about 10 turns and use a wheel puller to start getting it off. You might have to c-clamp the PTO/clutch top and bottom together to get both pieces off. Once the assembly starts coming down the shaft, you can probably remove the wheel puller, remove the bolt completely, and pull the PTO/Clutch off by hand. Be sure to unplug the PTO/clutch before removing it. Also, many of these have a spacing washer on top of the PTO/Clutch that comes off in the process. BE SURE to put it back on before replacing the PTO/Clutch. DO NOT hit anything with a hammer to try to break it loose - you'll most likely NOT get the part off and most probably WILL damage necessary parts.
Jul 29, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
How do i remove the PTO from an IH 856. The lower PTO shaft broke and the unit will not slide out
make sure all the bolts are out should be 1 short bolt and 8 long bolts to remove pto after that it is stuck to gasket. short bolt is in lower left corner of housing
Dec 26, 2012 | Farmall IH Tractor 706, 756, 806, 856,...
Briggs&straton all the oil leaked out from under the engine. the engine oil
hi there donald77
provided you have not got any cracks in the sump plate and the sump plate bolts are tight
sounds like you have a worn out pto seal ( please check pto for bend or wobble ) as this could have caused this from hitting something solid
it it is bent have it straightened before proceeding
remove the blade carrier and hub and key - clean up the pto with emery tape , drain oil , use a straight shaft flat blade screwdriver and lever the seal out of position
obtain a new seal place some thin plastic sheet ( from say a thin walled plastic container )
cut into a size that you can wrap around pto , then slide the seal over it up to the opening ,
the drive the seal into the housing squarely until the seal is flush with the housing ( on a non stepped pto ) 7/8 shaft
but on a stepped pto 25 mm drive it in further until its about 3 mm below the housing
reassemble and refill with oil
cheers hope it helps
pauly46
May 30, 2011 | Garden
8N PTO will not disengage
Pulls the bolts from the lever cover. You should be able to remove and inspect to see if the fork is busted or shaft it bent. go here for tech help and or parts/ manuals...http://www.just8ns.com/index2.htm
Jul 09, 2009 | Ford 8N Tractor
Drive pulley won't come off engine shaft
May 24, 2009 | Mtd Garden
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
