<!-- from fixya rte -->How do I fix the error be on my washer - Washing Machines
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Unplug washer for a couple minutes then plug back in,this should clear the code
Posted on Nov 12, 2014
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
Nf code and donnot continue to next cycle
Samsung Washer Error Code NF (Fixed ...
www.appliancerepairlesson.com/.../samsung-washer-error-code-nf-fixed/
Jan 11, 2014 - What does the error code NF mean on a Samsung washer? ... You can set the washer to any cycle and test each solenoid for proper voltage. ... Next would be to check the screens on the back where the water hoses connect. ..... Hi, you don'thave any power to the water valve wires when it should be filling?
Dec 15, 2015 | Frigidaire Affinity ATF7000E Front Load...
Have a top loading Kenmore elite high efficiency washer model 796.2927, 2 years old this thanksgiving is showing erroe code LE? what do i do to fix?
On most Kenmore front load washers the LE error indicates a LOCKED MOTOR ERROR. This can be caused by:
  1. Loose motor harness connection.
  2. Failed HALL SENSOR.
  3. Failed STATOR.
  4. Failed ROTOR (cracked magnet).
Nov 06, 2012 | Washing Machines
I've been getting a F1 across the screen. What is wrong with my washer. What can I do to fix it.
Hi
Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this error, you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error f35? What's the fix?
They can and fixed my washer today! The fix was the replacement of a switch. The item # was W10156252 for my washer. It is called a switch-WL. Item # may be different for your model. I was getting SUDS and F35 errors. To install it you just remove the top part of the washer and should be located at the upper right-hand side, attached to a black hose. The switch has a small computer board. The price of the swith is around $130. Fortunately I bought a 3-year warranty on my washer.
Apr 18, 2010 | Kenmore Elite HE5t Washer
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
F-23 error code
HOW TO FIX WHIRLPOOL WASHER F23 ERROR CODE What does F23 mean on whirlpool washer? It means there is a heater failure. If the water temperature in the washer fails to reach 86 degrees or higher then the washer will give the F23 error code. To fix the whirlpool washer f23 error follow the steps listed below.
Note: Some models do not have a heater as shown below, some models just have a temperature sensor. If your model does not have a heater just skip to checking the temperature sensor.
  1. First unplug the washer.
  2. Check the wiring to the heating element make sure its not burned, broken or corroded.
  3. Check the heating element for continuity of course if it does not have continuity then replace the element.
  4. Check the water temperature sensor wiring for corrosion or breaks.
  5. Remove the wiring harness from the temperature sensor and measure the resistance of the sensor. Refer to the chart below and if its out of range replace the sensor.
see link below for details and where to buy the part which is under $80 and fairly easy to replace
How To Fix Whirlpool Washer F23 Error Code Appliance Repair Guides
Jan 02, 2018 | Washing Machines
LG WM2277HW washer LE error
I was also having the LE error problem. I tried removing the unpumped water , tried re-running the load etc....... then I decided to try something else.... just like we have to restart our computers, I thought about resetting the washer so to speak......not sure if it is fixed, I am going to try running another load, but, I UNPLUGGED THE WASHER, LET IT SIT FOR ABOUT 10 SECONDS, THEN PLUGGED BACK IN.... AND THE WASHER WENT THROUGH A CYCLE AND FINISHED.
Jun 15, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
