Question about Water Heaters
I have a Heater which is a little over a year old and all of a sudden I don't have any hot water. How can I trouble shoot and fix this?
  • Water Heaters Master
  • 5,245 Answers
SOURCE: Rheem RTG 53 PVN with fault codes C4 or C7
I had the same problem with my tankless waterheater (flashing c4 76 alternately). I called Rheem
tech support and they had me 1 power down the remotepanel 2 unplug the unit from the wall 3 remove the cover 4 remove the wires for the remote panel from the circuit board and pull the twisted pair that goes to the remote out from the bottom of the unit. 5 reinstall the cover 6 plug the unit back
into the wall and turn on the hot water see if it works. It did in my case and they are sending me a new remote panel. I hope it helps.........
Posted on Jan 12, 2009
SOURCE: Our electric water heater doesn't work.
make sure it is wired correctly, check circuit breaker, check breaker built on to element. If all fails, and it is determined your not getting power to it, you may need a electrician. Be careful. good luck.
Steve
Posted on Oct 11, 2009
SOURCE: Water does not stay hot for very long. Runs out
The lower element probably needs replacement. It would probably be best to replace them both at the same time.
Posted on Dec 10, 2009
  • 148 Answers
SOURCE: Hot water does not last long.
probably has a bad heating element. May be a little limed up also. Drain the heater and replace the elements. Take a special tool to remove and replace the elements. ( fairly cheap) You can probably get the elements and parts at a good hardware store. The people at the store probably will explain to you how to replace them. Feedback please if this was of help
Posted on Feb 20, 2010
  • 68 Answers
SOURCE: Rheem tankless rtg 74pvn - heater hot water shuts
This is something you will have to contact rheem about due to the fact you don't have a fault code
Posted on Aug 12, 2010
Water not heating
Hey James,,
There is a couple reasons... the heater controls have quit working, the upper and lower heating elements have gone bad,,, the water heater breaker has tripped,,, Most newer units have a electronic pad the gives you codes as to whats wrong...mine has little flashing lights..
.If you can't trouble shoot, you need to get a qualified electrician to look at it... ask one of your neighbors if they know how..
This is a little deeper.. http://www.ragsdaleair.com/blog/3-common-water-heater-problems-that-make-your-hot-water-not-hot-enough-4
Jul 04, 2017 | Water Water Heaters
How do I trouble shoot a residential water heater
Hi Michael:
First off you have to determine what the SYMPTOM is that you are experiencing.
Example:
- water too hot
- puddle under tank
- very little hot water.
Then you can ask the FIXYA gang for help with the problem, or
You can research it yourself.
Jul 18, 2015 | Water Water Heaters
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
I replaced both thermostats and both elements in my 5 yr old water heater and I still don't have hot water. What else can I look for to fix?
Check that you are receiving 240Volt across top 2 screws on upper thermostat.
Copy following link for troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Jul 11, 2012 | RELIANCE ELECTRIC WATER HEATER
Have an LP gas water heater with White Rogers control that cycles on and off 3 times before remaining on. Water heater is 5 years old with forced exhaust. Heats water fine once it remains on. Do you...
From what you say, I would CLEAN the thermocoupler with either steel wool or a green scouring pad (dry) and then wipe off the residue with a clean cloth. If you still have trouble then it could be a gas valve that is sticking.
Jul 01, 2011 | White Rodgers Water Heaters
My hot water system tripping out the circuit break. I have checked the electrodes with an ohm meter and one leg is dead short to ground the system is approx 8-10 years old is there anything that can be...
Should be able to replace only the element. When you replace the element go ahead and replace both while you have the system drained down.
If you install a new one with an old one it will work it hard till th eold one goes. Also check out this trouble shooting guide on the link below for more info.
http://www.water-heater-repair-guide.com/electricwaterheatertroubleshooting.html
Jun 24, 2010 | Rheem Water Heaters
We have a new Rheem 30 gal short water heater. It only seems to put out about 10 gallons of hot water before it starts going cold,any suggestions......
I am assuming that everything was fine and then all of the sudden available hot water usage time dropped.
On a dual heating element hot water heater it can be
1. Internal tank loaded with sediment (drain and purge from lower garden hose fitting)
2. Thermostat or element problem with ONE of the 2 heaters. (Trouble shoot element thermostat)
3. Check Circuit breaker for partial trip of the breaker.
Feb 14, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Water Heaters Logo
71 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
