Question about Water Heaters
I have a Gas Hot Water Heater a little over a year old and all of a sudden there's no hot water
  • Water Heaters Master
  • 5,245 Answers
  • 68 Answers
SOURCE: poloma gas demand heater only getting warm water not hot 10y old.
move the dial up and get back to me
Posted on Jan 20, 2009
  • 234 Answers
SOURCE: I have a Rheem EcoSense hot water heater and all
Have you try to reset the power to the heater?Then turn the hot water facuet on to see if it will start up.
Posted on May 02, 2009
co7196
  • 3433 Answers
SOURCE: gas smell during startup of GE hot water heater
yes, provided there is no excessive build up. The gas and air mix must be right before the mixture will ignit. a household stove will do this each time it's turned on. That's why yhe igniter sparkk hits about three times before it lights. proper venting will confine any fumes to the cimbustion chamber to be carried out the exhaust. If the odor is strong then have the appliance checked for safety sake.
Posted on May 06, 2009
  • 244 Answers
SOURCE: richman gas lp tankless hot water heater. used for
I had the same problem with my Paloma a year and a half after installation...contacted Rheem\Paloma\Richman customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Posted on Nov 11, 2009
SOURCE: Water does not stay hot for very long. Runs out
The lower element probably needs replacement. It would probably be best to replace them both at the same time.
Posted on Dec 10, 2009
Why does the water suddenly runs COLD after many minutes of running hot?
Unless you are using a tankless hot water heater, there is a limited amount of hot water available in the tank. Electric and gas water tanks need time to recover after use, and if you are using heavily, it can exhaust the available supply. That said, there are a couple reasons why you may have less hot water than seems normal. In both electric and gas water heaters, silt can form in the bottom of the tank. This will build up over time and displace water. It also reduces the heating efficiency of gas units. There is a drain valve on the bottom of water heater tanks to allow for purging of this silt periodically, but few ever do it. You could also have, in the case of an electric hot water heater, a bad element or thermostat. Most electric heaters have an upper and lower element and thermostat. If one fails the other will still work, but the water takes longer to get hot and will deplete faster.
Nov 04, 2015 | Water Water Heaters
Noise blower motor
leave unplugged... water will stay hot.
Plug in for 1 hour to make tank of hot water
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 18, 2014 | Water Heaters
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
I have a Reliance 606 natural gas water heater. It is 8 years old. The pilot light went out on it and I replaced it. I lit the heater and waited 30 minutes to check the water temperature. The bottom of the...
1) Bad gas control thermostat, or thermostat has come out of calibration, or water leak running hot water out of tank.
Turn up temperature.
Replace gas control valve.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Clean air intake, put ear against pipes and listen for water leak, check that flame is clear blue and that combustion gasses are flowing up the vent pipe and not blocked.
3) Call service technician.
Dec 31, 2012 | Reliance Natural Gas Water Heater Control
Tankless on demand water heater.
Tankless water heaters normally take a little longer than a regular heater to provide hot water because they have to start and get warmed up. I'm guessing the heater uses a pilot light and that the short amount of hot water when you turn on the tap is hot because when the water is sitting still in the heater the heat from the pilot light is enough to get it hot. The tub faucet will get hot a lot faster than the shower because it lets a lot more water through and empties out the pipes faster than the shower. You could probably speed things up by letting the tub faucet run on completely hot for like 10-15 seconds and then turning on the shower.
Oct 24, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
Gas water heater goes cool
The dip tube which carries the incoming cold water to the bottom of the tank is bad/gone. If you can find a rheem dealer you MAY be able to get a new one but it's probably time for a new water heater
Jun 19, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heaters Logo
183 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
