Sanyo buzzing but can still hear show playing
    Top Expert:
  • Televison & ... Master
  • 75,591 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Nov 12, 2014
Sanyo Problem
It sounds that the back-light inverter board has the fault. It is a common fault, that the transormers in that board to get bad. If so, there will be a buzzing sound, when the set is switched ON.
May 28, 2013 | Televison & Video
Play xbox sanyo tv
The best option is to try a different component cable and inspect both ports for any wear.
Alternatively, try the same cable on another TV if you have one near by.
Jul 01, 2017 | Sanyo DS20425 20" TV
Sanyo flat panel tv has buzz overlaying sound
two things, does it do this when a dvd is played using a rear audio/video input: and is it there if sound is all the way off or muted?
Dec 19, 2012 | Sanyo Televison & Video
One channel won't play
With it connected to the amp remove the wires to the cartridge. With the amp on touch each wire with your finger one at a time. On one wire you should hear a loud buzz on the left. On other wire the right. The two other might produce a minor buzz or nothing at all, so ignore them. If you hear the buzz on both channels there's something wrong with the cartridge or the connection to it.
If you don't hear the buzz. Then (1) there's a bad connection between the deck and amp (phono plug or wire). (2) failed pre-amp inside the record deck itself. (3) failed pre-amp in the main amp. (this would not affect any other settings in the amp so tape decks will play normal etc).
May 26, 2012 | Denon Audio Players & Recorders
Won't turn back on and making a buzzing sound
The tv FBT-(Flyback transformer) high voltage is dead,that why u hearing a buzzing sound.The FBT is the big black block of plastic with a red wire with a cap that hook up to the CRT-(tv tube).
Mar 29, 2011 | Sanyo DS35510 35" TV
Television was playing and all at once the white screen appear.
If you still have warranty I would run not walk to the service center. This could be a very costly out of pocket repair.
May 01, 2009 | Sanyo DP32746 32 in. LCD Television
Bose Lifestyle CD not eject
There are some repair instructions available at www.AnyoneCanFixIt.com in the electronics section that will show you how to release the CD magazine and fix the problem where the unit will not play the CDs (you will hear a buzzing, buzzing, buzzing, and nothing will load or play).
Oct 11, 2008 | Bose Lifestyle 20 Shelf System
Sanyo dvd/vcr dvw 7000
I have a Sanyo Dvd/vhs player and I recentlty went to dish network instead of cable and I do not know how to get the player to work now so I can watch movies that I have rented. Can you tell me how to use the remote to watch movies.
Apr 08, 2008 | Sanyo DVW-7000 DVD Player/VCR
Sanyo television
That set is probably not ready for the dump yet. The buzzing sound could be the power supply going into shutdown because of a shorted secondary supply, usually a shorted horizontal output. A good tech should be able to fix that at a reasonable price.
Jun 28, 2007 | Sanyo DS32224 TV
High pitched buzzing...
noisey yoke? Listen thru an empty paper towel roll cylinder to isolate---
Nov 17, 2006 | Sanyo DS27910 27" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
