Question about Whirlpool Washing Machines
How come Whirlpool won"t cover Error code F 51 for their washing machines. Because of what I researched. A lot of their washer have this code F 51 problem. BY the looks that there are hundreds if not more that has have this same code. no matter if you don"t have a warranty. Don't figure.
    Problem Solver:
  • 15 Answers
Only the first year. As all washers. F51 is a error for RPS sensor, it ends up as a kit w/wire harness.
Posted on Nov 28, 2014
WASHER NOT WORKING CODE CI
This means Instantaneous current overload.
This may signify problems with the drive motor, thermal protector or motor controller. Overloading the washing machine may cause this.
for more info download the manual at
http://www.manualslib.com/download/193839/Whirlpool-Calypso-Gvw9959k-0.html
see page 51 on error codes for this unit
Nov 06, 2013 | Whirlpool Calypso GVW9959K Top Load Washer
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer keeps displaying a code of f 51 what is the problem
Basically, the F51 error is a rotor position sensor error.
Thank You
Sep 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code 51
there is a rotor position sensor failure.look under the top hood of washer on the inside of the front of washer and you will find a tech sheet that will help with this problem use a flat blade to push two clips in to get hood up.
Jan 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio washer is giving an F 51 Code
The "F51" error code is common problem with the Cabrio. This is an RPS sensor error. The sensor is mounted along the motor windings under the washer and detects the rotation spin speed. The sensors on these units can go bad, causing the error code, and it has been a frequent problem. I would recommend you contact Whirlpool first (due to the unit only being a year old) and see if there is a recall or upgrade on this part. I believe there is. The repair would then be covered by the manufacturer. If I give you the steps to access and/or replace the sensor at this point, you may be voiding any existing warranty you may still have. Some components carry a longer warranty than your normal one year limited warranty from the manufacturer. Something you may consider.
If you have further questions, please let me know. I hope this helps you in some way.
Jun 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio HE washing machine displays error code F51. What is it and hw to I fix it?
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Jul 27, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
117 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
