Question about Sony VAIO Computers & Internet
How do I fix one of my laptop keys?
My D key is having some trouble. Sometimes it doesn't work at all and sometimes it gets stuck and when I type all I get is "dddddddddddddddddddddddddddddddddd" Right now it's not working when I press it but is working at random, making this hard to type. Do you think it just needs to be cleaned or do you think it's a hardware problem?
    Top Expert:
  • Sony Master
  • 21,472 Answers
It probably has a bit of grit or some foreign object under the key or the keyboard just needs replacing.
Posted on Nov 12, 2014
  • Samuel L
    Samuel L Nov 14, 2014
    Okay thank you. I will have someone look at it.
TeK Micro
  • 62 Answers
SOURCE: acer Aspire 5610 - one key does not work
Laptop keyboard are semi-sealed circuit boards. This means that liquid can get into the contacts and can not be cleaned. Depending on how much liquid was spilled on the keyboard chances are that the liquid has seeped around the edges of the keyboard and down onto the mainboard of the laptop. My first suggestion would be to keep the laptop turned off until you can remove the keyboard and check for liquid damage to the mainboard. If there is no damage to the mainboard I would suggest buying a new keyboard before turning the computer back on as any shorts caused by the liquid damage on the keyboard can cause damage to the keyboard controller circuit on the mainboard.
Posted on Jan 03, 2008
  • 13 Answers
SOURCE: keyboard not working
It sounds like something with sugar was spilled on it, however there is another issue that could cause this. If the ribbon cable for the keyboard has jarred loose but not came entirely unplugged it could cause the same situation if its happening in all programs. If its just the keyboard usually they are not too expensive to have replaced.
Posted on Jul 23, 2009
  • 83 Answers
SOURCE: Hi, I have a compaq nc6400 laptop. When I press
Your Keyboard needs to be replaced, I had a family member with the same issue.
Posted on Apr 13, 2010
Testimonial: "Thanks for your suggestion. Many other also suggested the same thing. I think I will do that. "
  • 104 Answers
SOURCE: how to fix a stuck key on a sony vaio
You need to replace your keyboard. You can find them cheap on ebay. The actual replacement is quick and simple. On the superior part of the keyboard, if you look closely there's some spaces, with a flat screwdriver very gently lift them up until that panel comes off. Then just take the keyboard out, you should see the ribbon cable. On some models you need to take out a couple of screws from the battery side. As always remember to remove all power sources (ac adapter and battery) before working on your machine. If you still have questions, comment here and I will get back to you as soon as I can.
Posted on Feb 27, 2011
MSG-CPC
  • 1325 Answers
SOURCE: I have a Dell latitude E6410 laptop computer. it is about a year old. Lately I've noticed that when I type not all of the keys respond. Sometimes you have to click on the key several times to get
you have to replace the keyboard
here is how to do it
http://www.youtube.com/watch?v=m25N1eZj1FQ
here is the part number to order
Item Number: 330-7359. Part Number: RRGD8
Posted on Jan 03, 2012
Testimonial: "Thanks very much, this was very helpful"
My laptop keyboard can't work, its locked and i cant type
This can be done by software (locking the keyboard). I'd try a hard reboot, and see if that solves the problem.
If that doesn't work, sometimes keys get stuck down and cause the keyboard to stop working, it's odd but I find pressing (mashing) each of the keys 2-3 times will often fix keyboard issues. I typically start with the common keys like the ctrl, alt, shift, space, enter, etc.
Hope that gets ya moving again.
Apr 07, 2014 | Microsoft Office Professional 2007 Full...
Noisy "F" key if I apply too much pressure on the f key - is normal? HP ProBook 4540s
well...sometimes i press buttons for too long and they make that sound but getting it from yesterday....ohhh i have a Windows Vista the O button came off and the W dosent have its Plastic thing to help me type anymore. your luckier then me.
Jan 13, 2013 | HP Computers & Internet
Shift button does not work in laptop
Sometimes keys get stuck and sometimes the contacts don't work anymore. Carefully turn the laptop over and gently tap it on the back to knock out any grit that might be under the key. You can also carefully use a soft paint brush to see if there's any hair, dirt or grit around the key that is preventing contact. You can also try canned air to spray out dust. If you have a pet it's quite common to get fur in the keyboard even when the cat or dog isn't near it :)
Keys on laptops don't come off and go back on as easily as they do on normal keyboards so removing the key might get you into a fix...ie break it. So I wouldn't recommend trying that if you're not familar with how it connects.
It could be that the mechanism has worn out in which case you'll have to replace the keyboard itself.
Jul 25, 2011 | Toshiba Satellite 1400103 PC Notebook
The phone is suddenly behaving weirdly. sometimes the keys doesn't work sometimes sometimes the touchscreen doesn't sometimes it switches off on its own. how to repair it i don't know
hello there.. i think that's a phone problem that you yourself cannot fix. you need to go to a service center to let them check what's causing the problem.
but before you do, kindly answer the following questions i have for you:
1. did you recently download any types of application to your phone?
2. did you drop your phone?
May 19, 2011 | Samsung B3410 Cell Phone
Sometimes the keys work and sometimes I have to
take a vacuum cleaner and clean the keys nicely... might be something is stopping it ,,, it still the problem is there u would have to replace it
Jan 12, 2010 | Dell 0Y3740 Keyboard
Sometimes my wireless keyboard will type multiples of the same character when I've only hit the key once, and then other times it won't respond and will end up typing the first & last letters of a word...
Try plug it in to another USB port while the PC's switched on. It will force the computer to redect your mouse and keyboard and might fix the problem.
Another test would be on another PC or laptop. If it does the same thing then the keys are probably getting stuck down. Has it had anything spilt on it? Try a vacuum over the keys, you'll be suprised what gets caught under the keys (usally paperclips!!).
Dec 14, 2009 | Computers & Internet
While starting my Sony VAIO laptop, it beeps, (short toned but continuous) and pressing Alt / Ctrl/Del or function keys stops that noise , then system is getting booted. Every key is working except 'q' and...
Yes. Get a new one! The keys are stuck when you apply too much pressure on them, and check for foreign objects between the keys. Use compressed air first, if that don't work you have the option to spend money to get it diagnosis at a computer shop or buy a new one.
Sep 02, 2009 | Sony VAIO VGP-WKB1 Keyboard
I have an Acer Aspire 5515 laptop. When Im typing the lers sometimes dont show up. Ihav to hit the letter key a couple times for it to work sometimes. any suggestions on how i can fix it?
first of all u need to remove ur power plug and the battery
then pull a little Aciton around each button which stuck
use any cool air dryer and direct it through these buttons which u have put an Aciton on it
keep ur cool dryer ( not hot air cool air plz) about 5 min. directed to the buttons
leave it about 30 min
if this not work then try this
u need to clean ur keyboard cause it seems that ur key is stuck so u need to dissassemble ur keyboard and clean the carbon points in ur keyboard (after u dissassemble it) using Aciton and tishue
otherwise u need to change ur keyboard
Jul 30, 2009 | Acer Computers & Internet
Open Questions:
Computers & Internet Logo
43 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
