I need Trane Model TCH330 please advise how many ton
    Master:
  • 876 Answers
Per the Trane document at:
http://www.trane.com/download/equipmentpdfs/rtprc007en_0404.pdf
it's 27 1/2 ton
Posted on Nov 13, 2014
3 Suggested Answers
  • 252 Answers
SOURCE: Need Tons on a btb736a100a2
3 ton
Posted on May 07, 2009
shastalaker7
  • 1515 Answers
SOURCE: I have a Trane Model # TWE048C140C0 Serial #
The tonnage of this unit is the 48 you find in the model. Each ton of cooling equals 12,000 B.T.U. So, 48 would be a 4- Ton Unit. 48 divided by 12 =4x12=48.
Shastalaker7
Posted on Feb 22, 2010
I have a XB13 model number 2TTB3048A1000AA what's the tonnage
The 48 in the m# tells me it's a 4 ton. There's 12,000 BTU's in 1 ton of cooling. 12 into 48= 4(ton). It's possible that the 30 in m# makes it a 2.5 ton/sometimes confusing but I'm near certain it's a 4 ton trane or am. standard unit. Hope this helps!
Aug 20, 2017 | Heating & Cooling
I have a Trane XB13 model number 2TTA3048A1000AA what's the tonnage on this unit
The 48 in the m# tells me it's a 4 ton. There's 12,000 BTU's in 1 ton of cooling. 12 into 48= 4(ton). It's possible that the 30 in m# makes it a 2.5 ton/sometimes confusing but I'm near certain it's a 4 ton. Hope this helps!
What is the capacity Tons or BTU for TRANE Chiller Model# CGWA4005-MA; Ser# L6A717192
The Trane corporation is not forthcoming with that info: http://www.trane.com/COMMERCIAL/DesignAnalysis/SoftwareSupportEmail.aspx?i=1442
Feb 09, 2017 | Heating & Cooling
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
I have a Trane Model # TWE048C140C0 Serial # 2261X5Y2V what is the ton rating for this A/C unit?
Shastalaker7
Feb 22, 2010 | Heating & Cooling
3 ton condensor and 2.5 air handler
I hate to use rules of thumb but 500sqft per ton depending on your windows and insulation. you are probably ok with a 2.5 ton however it will not work with a 3 ton outdoor unit as you have figured out. depending on how long that ac has been in you may want to replace it with a 2.5 ton due to the damage to the compressor valves because of the mis match. or if the indoor is newer and the original system may have been a 3 ton then i would replace the A/H. and be prepared to replace the outdoor if the valves are to far gone. If the trane is a new high effiency 2 and the goodman is just a 10 SEER you may be able to have a txv installed on the trane unit and a kickstart device outside. but only if its a high effiency but their again if the A/C fails you couldnt have a high effiency 3 ton you would have to drop down to 2.5,
Sep 22, 2009 | Heating & Cooling
Need a schematic diagram on a trane furnace model blu080k0942b0
Have you checked on the inside of both front panels?
Mar 05, 2009 | Heating & Cooling
Heating & Cooling Logo
110 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
