Question about Frigidaire Stove/Oven/Range Glass Main Top - 316456246
Top main burner want turn off
Main burner want turn off
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
Switch is either bad in it or has food/grease build up not letting it shut off.
Unless its a newer model and is push button?
Posted on Nov 12, 2014
How do I fix my left rear burner that has stopped working?
First of all, you need to test the wiring to that burner. If there is no electricity, then you need to replace the plug in. You can get them at an Appliance parts store. If there is electricity, then all you need to do is get a new burner at Lowes or Home Depot. Sometimes the burner gets a tiny crack in the burner that breaks the continuity.
Sep 01, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
Two burners on thermador cook top turn off by themselves
It is common for electric coils on a range top to click/on/off. They are suppose to reach a certain heating range and when satisfied, they go neutral and when the demand for heat is needed, they become energized again.
Feb 09, 2018 | Thermador Cooktops
Center Burner stays lit and will not stop trying to ignite unless it is unplugged. If I need to order parts please tell me what I would need to fix this problem.
Hello Donna ,
If by saying "stays lit" ya mean that the flame goes off when turning off the knob yet it continues to spark all the time ?? if yes that's whats happening the flame goes off but it keeps sparking whats wrong it that the switch that turns on the spark when the knob is turned is bad and that is what needs to be replaced. GE only makes that switch available in a complete assembly with all 5 switches and the wiring for it. It's not to bad to replace that actually,what ya would need to do to replace that switch harness asm. ya need to take off the main top which can be done by removing the burner grates and caps from the burners,then is the outer center of each burner will be 2 screws remove those screws from all burners then the all 5 knobs and the top will lift off,that switch harness has keyed plugs and will only fit in one way so its not to bad to replace it. The part number for that switch/wire harness asm. is WB18T10381 it could be purchased at your local appliance parts store or online at; searspartsdirect.com apdepot.com partselect.com apwagner.com repairclinic.com
Thank you for using Fixya.Com,if you should require further assistance please reply and i will be happy to help,
GENE
Oct 04, 2011 | General Electric MonogramĀ® ZGU385NSMSS...
When I turn any burner on, the ignitors work fine but it takes a very long time for the burners to ignite. Problem is worse the longer the top has been turned off. Once gas gets to the ignitor, it lights...
It seems like one of your burners is clogged. You made need to use some oen cleaner and a small toothbrush to clean the burner. If the problem occurs with all the burners, then you have a blockage in the gas supply line. you willm have to take it apart at the stove and clear it out. Check the main gas connection and at the burner(s) to spot the debris clogging. Make sure to shut your gas valve off behind the stove. Good luck... hope this helps.
Jul 15, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Large electric burner will not turn on
you need to check the wiring to that burner it appears that there has been a short to the burner
Apr 04, 2010 | Jenn-Air 35 in. JEC9536ADS Electric...
2 right burners on my Jenn-Air JEC9536 cooktop stopped working.
I have a JEC9536ADB electric Jenn-Air Cooktop. We replaced the class top and now the knobs are all spliting and won't work. 2 of the main burners will only heat in the "high" position? What do I need to replace?
Sep 25, 2009 | Jenn-Air 35 in. JEC9536 Electric Cooktop
Thermadore cooktop SGCS365RS
if its one of the center burners witch has the auto on off for extra low its the moduel under the handle
Potentiometer
Jul 19, 2008 | Thermador SGS36GS Gas Cooktop
Cook top
Sounds like you have cartridge fuses in your house. When only one is blown it can cause interesting results. The clock is probably feeding back through the burner. This lets enough electricity through to run the clock and othe small things but not enough for heat. Have all the cartridge in your house tested. I'll bet either one of the mains or range ones are bad.
May 28, 2008 | Frigidaire Cooktops
Main burner will not turn off!
Burner control feel loose? Wheter it is or isnt that is probaly where your problem is..
Jan 20, 2008 | Kenmore 30 in. 42701 / 42702 / 42709...
Frigidaire Stove/Oven/Range Glass Main Top - 316456246 Logo
95 people viewed this question
Top Frigidaire Cooktops Experts
Oloyede Monsuru
ray gallant
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
