Question about Acer Computers & Internet
After a power outage, my monitor will not come back on. I have unplugged and plugged it back in and still nothing. Is the monitor toast.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
What Model is it? Does it do nothing at all, or does it flash briefly, and go blank?
Posted on Nov 12, 2014
skotkolr
  • 558 Answers
SOURCE: monitor
I think your resolution is set too high reduce it in safe mode
Posted on Dec 09, 2008
  • 152 Answers
SOURCE: Dell flat pannel monitor fail to power up after power outage
rtutt, First, before you start to tear apart the monitor any further, take pic's (close-ups) of screws, cables and their positions BEFORE detaching them from their board mounted jacks. Second, the fuse will be a small pigtail type soldered to the power supply board. It's the board that will have the connector on it that the line cord plugs into from outside the plastic cover. This is Pretty neat for you because if you forget where something goes, you can always open up another monitor. Well if you get the steel shield cover removed (BE VERY CAREFUL NOT TO RIP OFF ANY CABLES OR MULTI CONDUCTOR RIBBON FLEX CABLES) the cables can then be popped off. you can probably catch a video of monitor tear-down on YOUTUBE.com by doin a search on LCD repair. Yes I have seen some that are 8 to 12min long on the tube. Also you will be visually checking all large electrolytic capacitors for SWOLLEN tops of their aluminum can. You will need a large magnifying glass to inspect the solder side of the board for circular hairline fractures around the leads of heavy and larger "through-hole components, that have been thermally/mechanically STRESSED over the years. they will need to be resoldered. Well any way, keep me posted of your progress. Im louie12fix or lmistyrel@ aol.com PS: I have dell and will take pic's of board!!
Posted on Apr 08, 2009
  • 164 Answers
SOURCE: Samsung 913N Monitor went out after a power outage.
try a known good monitor on the PC, is the light blinking green or orange?
www.aa1consuling.com
Posted on Jul 24, 2009
budmrtn
  • 11361 Answers
SOURCE: monitor blinking after power outage
Check the power supply section first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 27, 2010
After power outage front display blinking "16".
I had a similar issue where after a power outage, the player would not power up.
I removed it from power and took the cover off looking for a fuse. Could not find anything so I put the cover back on and plugged it in and it worked. My theory is the electronics needed time to fully discharge in the circuits. I would leave it unplugged for about 24 hours. I left mine unplugged for several days. I hope this helps.
Feb 13, 2016 | Toshiba SD-3990 DVD Player
What do I do after power outage and monitor will not work?
If the device was plugged in when the outage started and / or when power was restored - it may have suffered a power outage related voltage "spike" (or instantaneous rise in voltage greater than it is designed to handle).
Unplug it for 5 - 10 minutes and reconnect. If it fails to function you may need repairs or replacement. Try a different monitor on the computer before condemning it - it may be a problem with the computer's video card instead.
Mar 11, 2015 | Computers & Internet
Won't come on after power outage
Sometimes you have to unplug the monitor from the power supply and wait at least 30 seconds before plugging back in, and make sure you don't need to press the reset button on the power strip.
May 07, 2009 | Computers & Internet
Computer wont turn back on after power outage
Try unplugging the cord from the back of the computer for about 5 minutes and then try it again
Apr 14, 2009 | Compaq Computers & Internet
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Olevia
You should check to see if the sound is really coming from the TV- you may have the sound from the directTV cable box composite audio red and white RCA connectors.
Try connecting from the audio out of the TV to the stereo
Try the menu and see if you can adjust vertical and horizontal hold.
unplug tv for 10 minutes - tehn try again.
change battery in remote, if the remote does not seem to work
good luck
Oct 26, 2008 | Televison & Video
No display
Your minitors power supply is now damaged, probably from the power outage. I t will need to be repaired or replaced. Check the cost and benifits of both options and make a discision.
NSSMS
Jul 30, 2008 | Acer AL1912 19" LCD Monitor
Canon MP830 power outage while printing
My MP830 did the same thing today. I thought it was toast. However through a Google search I found the following suggestion.
Unplug the MP830 for 20 minutes or more. Plug the MP830 back in and hit the power button.
To might great relief my MP830 powered up and is working just fine.
Jun 30, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Blinking monitor screen
this might be overly technical, but it sounds like the video card is on the blink (no pun intended). I'd power down the machine, open it up, pull the video card, re-seat it, and power the computer back on.
If it continues to do this, that card is probably toast.
Dec 06, 2007 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
