How do I start a philips hepc 8512 pc - power button led flashes red every two seconds - doesn't start?
Power button led flashes red every two seconds - doesn't start
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Posted on Nov 12, 2014
Benimur
  • 6966 Answers
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
Posted on Aug 26, 2007
mumma_1
  • 903 Answers
SOURCE: 42" philips plasma
when a television turns off by itself and flashes as you say, it indicates that there is a problem inside the tv. If you keep trying to turn it on you may do more damage. It could be something as simple as a faulty fuse inside. If you have no expierience with electrics I suggest you get it checked out by a professional. I had a similar problem with another tele model and it was the fuse in the back of the tele that needed changing. I did try to this on my own but unfortunatley didn't have the right fuse so i took it to a repair shop and he done it really quickly.
Posted on Oct 23, 2008
SOURCE: Panasonic TH-50PE700U red light flashing 6 times
Replaced the sc board and tv works fine again.
Posted on Jan 22, 2009
dsacco86
  • 1077 Answers
SOURCE: will not turn on
This might help you. Try starting on page 27 of this:
http://www.scribd.com/doc/6528782/Philips-42pf7320
Posted on Apr 05, 2009
SOURCE: Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Posted on Dec 14, 2009
How do I fix my desktop computer?
That flashing LED generally means a hardware failure. Your best bet is to take it into the shop.
If you want to try to fix it yourself, open up the case, dust everything off, disconnect and reconnect all cable, pull and reseat all cards. That probably won't fix it, but it's worth a shot.
You could also try pull any cards to see if you can get the machine to boot. But chances are that you have no cards, since most modern computers have everything on the motherboard.
I think that's a pretty old model of computer, so you may just want to replace it.
Nov 11, 2014 | Computers & Internet
Nov 11, 2014 | Televison & Video
SONY VPL FX-40 projector. After plug in-ON/Standby LED is red for few seconds and starts flashes in red(repetition rate of 12 flashes). After pressing I/O key-ON/Standby LED flashes in green(few...
A Flashing Red ON/STANDBY LED means one of the following
2 Flashes - The internal temprature is high. Check the air holes are unobstructed.
4 Flashes - The fan is broken
6 Flashes - The internal electrical system has failed.
There is no entry in the manual for 12 red flashes.
Feb 19, 2011 | Sony VPL-FX40 Projector
Philips Power supply flashes 5 times
one day not start his open. stan by red led and after switch on ,his green bligkig is not open.sound is ok.(the relay his not click)
Apr 12, 2010 | Philips 50PF7321D 50 in. Plasma HDTV
Retuning Philips DTR 1500 digibox
Had same problem. Remedy is to put digibox back to factory reset. Dis-connect from mains. Keep pressing + button on front panel as you re-connect to mains. Red LED will be on, when orange LED blinks release + button. briefly press + button. You have solid red LED and blinking red LED. Enter code 9 9 0 0, by remote blinking LED will show green. Wait a few minutes and the instalation page will appear on screen. Go to update and start as you did before and C5 should be installed. Hope that helps.
Dave
Sep 30, 2009 | Philips Televison & Video
No Pictre, Flashing Power LED - Philips 42PFP5532D Plasma
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 20, 2009 | Televison & Video
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Power up problem
Hi, you most probably have a sticky on/off switch on your case. Turn the power off. Remove the side cover, trace your wires from the front switch to the mobo, identify witch is the power switch [this is usualy marked with PWR or PWS on the board and also on the wire from the switch. Disconnect this wire then turn on the power and use a fine screwdriver to bridge the two pins on the board, if all works properly then replace the switch Regards mistyman
Sep 06, 2007 | E-Machines eMachines T3830 PC Desktop
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
