<!-- from fixya rte -->Can I get a new remote for hdmi ilo tv - Televison & Video
    Sergeant:
  • 311 Answers
Maybe from manufacturer.Possibly a universal remote can do the trick.
You will need model # and serial #,too.
Posted on Nov 12, 2014
Benimur
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
SOURCE: DON,T HAVE A REMOTE
will a universal remote wok with the iLO TV'S
Posted on Jan 17, 2008
SOURCE: ilo 27inch hdmi hd tv monitor
You would need to connect a VGA + Audio to HDMI Converter. The downsize it the converter goes for about $150 us
Posted on Apr 12, 2008
IrishDruid
  • 2712 Answers
SOURCE: remote code
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 19, 2008
SOURCE: need remote control code fro iLo TV
iLo Tv's are made by orion. When I used their code the Tv remote worked.
Posted on Dec 08, 2008
Where is the hdmi connection?
The Ilo IWT3206 is a CRT type TV; it does have an ATSC tuner to support digital OTA TV signals. It doesn't have an HDMI port. The best input it has is the component video in. There are HDMI to component converters. However, most of them have issues with digital rights management protections (HDCP). The manual for the Ilo IWT3206 is available from the manufacturer (Funai). Their support page is at http://www.funai-corp.com/support/manuals.aspx . The direct link to the manual is http://www.funai-corp.com/support/om/IWT3206.pdf .
I wish that I had better news for you. If you have a different model, please post a comment or a new question.
May 15, 2015 | iLO IWT3206 TV
ILO TV REMOTE CONTROL MISSING
Go to this webpage.
Here you can buy the original remote contol for your TV
http://www.remotes-express.com/Ilo/ILO2600.html
Jan 12, 2008 | iLO 2600 Television
I have an ILO HDTV. I try to change the station with the remote but the TV only changes the station between 2 and 22. It doesn't respond to my commands when I want to place it on channel 3 for my...
My ILO TV has a source selection that can select where the signal input is coming from that I want to display. Do you have the sat hooked up to an HDMI input? If so try selecting that. If you do have the option of using HDMI - buy a cable and hook it up between the sat (assuming it does support hdmi) and the ILO (mine does, and it about 5 years old). This is the least problematic way to make it work.
The Poodle Guy!
Nov 21, 2010 | iLO 2600 Television
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
How do i hook up my ILO TV to direct TV satelite?
i have a ilo 32 in hdmi hdtv and i have mine hook up to direct tv .on the back of the receiver plug your red,white and yellow into the audio 1 of the direct receiver. on the back of your ilo tv plug the other end to the av1 and use S-VIDEO ALSO. plug the sat cord to the ant.in. on the tv set remote hit video and go down to s-video and hit ok. you need to plug all three plugs into their color ans the s-video too in the AUDIO section. mine works great !
Dec 30, 2008 | iLO 3200 32 in. LCD Television
DON,T HAVE A REMOTE
you need to call akai they make the tv for walmart I had the same problem if you have a remote they will exchange it for right one
Jan 14, 2008 | iLO 3200 32 in. LCD Television
Ilo 27inch hdmi hd tv monitor
Jul 31, 2007 | iLO V27DMBX Television
Need new remote
Hey you should try finding an exact replacement for this ilo hdtv. If you have your model number for your ILO hdtv you can go to a website like http://www.remotecontrolscenter.com and look through their catalog for a new replacement remote control, which is the exact same remote you got in the box with your ILO TV and should work right out of the box, unlike most universal remote controls. If they can't help, there are alot of other major replacement remote companies out there! Hope I helped!
Jul 30, 2007 | iLO V27DMBX Television
Volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Dec 01, 2006 | iLO 2600 Television
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
