Question about Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune topload washing machine, Model #FAV6800AWW. When washing machine is finished the clothes are still wet but no water in the drum. Also we have noticed that during spin cycle th
I did put a new mother board in this machine almost 2 years ago.
  • 34 Answers
Before calling for service:
If clothing is still wet it means no spin. The most common problem with this model is a loose connection from the lid switch to the control board. Two white wires going from the lid switch to the control board should be cleaned. Do not touch the control board - especially in dry climates. Static electricity can ruin a board.
Posted on Nov 12, 2014
Testimonial: "I will check this this evening and let you know the out come. By the way do you know if there is a filter of sometype that would catch lint/dog hair/etc..."
  • 101 Answers
First check if the motor is running on spin cycle. if it is Check adjustment or wear on gearbox plastic pulley. Check motor tension spring is intact. Check motor slides freely. if no problem found the internal clutch is faulty, replace gearbox.
    Master:
  • Maytag Master
  • 676 Answers
Have you got any error codes like DC or unbalanced load if so you may need a clutch
    Sergeant:
  • 311 Answers
There are a few choices for spin cycle speeds.
Use the fast one.
Don't put anything in there that is waterproof or water resistant.
4 Suggested Answers
  • 901 Answers
SOURCE: maytag neptune washer mah1 has a pool of water
If motor is not gaining speed during spin check the capacitors.
Posted on Apr 01, 2010
  • 6277 Answers
SOURCE: Maytag Neptune washing machine does not spin out
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 08, 2011
FAV6800AWDIY
  • 526 Answers
SOURCE: Water leaking from my Maytag Neptune model
Could be a Tub Seal leak my 1st choice. Could also be a leak caused by a cracked outer tub, issues from the hoses from the drain line connections to the drain pump, drain pump and or drain line.
Are you going to try to DIY the fix?
Posted on Sep 07, 2011
Water leaking from my Maytag Neptune model FAV6800AWW Serial number 15646382GA Leaks during wash cycle imediately and during complete cycle. Enough water to saturate 2-3 towels and clothes come out...
Sep 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL ( Model # FAV6800AWW) washing machine does spend but clothes still soak after it done. when you spend it by hand, it only spend in counterclockwise.
Any error codes. What happens if you start a Spin Only Cycle witht the same load? Does the times stay stuck at xx minutes in the LED display and the machine constantely starts and stops?
The more info on your problem the better.
Do you want to DIY the fix? Google this; Neptune TL Washer FAV6800AWW see the 5th post down here for general info and the Service Manual. If you want to try to DIY the repair I will help.
Apr 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I start load of wash, with setting of Max Extract being ON. Clothes come out very wet
I would put the machine in Service Mode with that Wet Wash Load in the wash basket and do a Quick Spin Test on page 14 of the Service Manual and record the fastest RPM that the wash basket will pin up too.
If you don't have the Service Manual Google this Neptune TL Washer FAV6800AWW
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
If you want help post your issue in that Maytag DIY froum and I will help you......or stay here and see how it's goes.
Mar 21, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My MAytag will not spin the water outta my clothes on spin cycle
If you machine is a FAV6800A or FAV9800A don't worry about the last two letters of the model number.
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help.
Feb 28, 2011 | Maytag Neptune FAV6800AW Top Load Washer
ND error, pump runs, but sounds rough, took pump apart and found nothing in the pump or pipe.
If the motor is running but there is no water coming through, it would suggest the pump impellor blades are compromised. It's quite posible that the shaft that drives the blades has snapped. Is it possible to open the pump housing and rotate the blades manually whilst watching the motor to see if it moves? If one moves without the other, then its a new pump I'm afraid. WARNING! Do NOT attempt to do this with the motor connected to the electricity supply.
Feb 12, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag toploader Neptune washer stops with 10 minutes left on quick wash and code "uc" on LED. There is a little water left in bottom of tub and cloths are soaked. It does fine until the spin...
It sounds like the Outer Bearings are going due to a leaky Tub Seal. Bothe can be repaired and have done on this site. This site has no way to reference past post to machine issues.
I have helped owners of theFAV6800A and FAV9800A machines here but I prefer a tru DIY site.
I no longer post on this site no way to post a Sticky for machine issues.
If you want to DIY the repair Google this phrase ""Sticky: Neptune TL Washer FAV6800AWW""" Read the post Part 1; DC or UC unbalance error codes in Spin Cycle what is causing this issue? Part 2 for the fix action.
Post your issue in the repair forum not in the Sticky. Please include your Model Number i.e. FAV6800A or FAV9800A and I will help you.
Jan 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune topload model fav6800aww. does not spin
Thank you for posting your model number.
Are you taking error codes to the LED display such as dC or uC with fail to complete spin cycle?
Is the wash tub banging the sides of the machine at the start of Spin Cycle?
Will your FAV6800A complete a spin only cycle with no clothes in the wash basket?
If you are going to DIY the repair take a look at this step by step process Clutch Fix Post
Basic mechanical skill set and hand tools are all that is required. I can help you through the process just let me know what direction you want to go.
Links to the FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
If you can give me the first two digits of your serial number of your machine it will be 10 through 17?
Jan 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Mar 31, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Soap residue
if you just have a soapy residue( bubles atop the clthing?? either your using way to much soap, or way to much of wrong soap.you need to use HE detergent specifically formulated for front loading amchins(low sudsing. or your having a cold water inlet problem set te hunit to cold/cold/ try running see if inded the machine fills
Mar 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
265 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
