Question about Sharp AR-M205 Copier
How can I use Adobe Acrobat 10 to scan with Sharp Copier AR-M205?
My Sharp Scanner was scanning black and white only and suggestion was given to use Adobe to scan. I have now installed Adobe but I cannot use it to launch the scanner.
  • 328 Answers
From control pannel of your pc ,go to the scanners and camera and see your AR_M205.then dubleclick on it.ok?
Posted on Nov 27, 2014
SOURCE: System settings on Sharp AR-M205
Found a very good solution...Use Adobe Acrobat to do the scanning. Launch Adobe Acrobat and select the AR-M205 as your scanner and proced from there. Adobe will pull up the Sharpe software to do the actual scanning but Adobe will be in charge and create a pdf file. I am using Adobe 6.0 which is not one of the free versions, I think.
Posted on Dec 29, 2008
  • 54 Answers
SOURCE: Sharp AR M455N copier scanner will not scan to Windows 2000
Check the webpage under destinations and make sure the IP address is correct for this pc. can get to webpage by opening Network Scanner tool, hitting the scanner tab, then web setup button.
Also make sure the Network scanner service is running in the system tray (by the clock) and that it says the service is started by hovering over it with pointer.
Posted on Apr 17, 2009
  • 54 Answers
SOURCE: Error CE while scanning though N/W in Sharp AR M-205
If subcode is 00 then network connection is problem, if 02, then its not talking to the network scanner tool on the computer. Might be an IP address problem, where the address in the webpage of copier is wrong for the PC.
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
ermiaby
  • 54 Answers
SOURCE: free download drivers of sharp ar-m205 black and
see www givememyfile.net
Posted on Jan 14, 2010
Cannot scan in color. can only scan in gray.
That is because it is a Black or White copier. It will not scan in color, it is not designed too
Jul 31, 2010 | Sharp AR-M205 Copier
We want to be able to scan from our copier to our
He's wrong, but with all due respect, it's not going to be accomplished by you without the help of someone who knows this product.
Feb 02, 2010 | Sharp AR-M205 Copier
One of our Sharpdesk users is unable to view her .pdf files that have been scanned in (as a .pdf) and sent to her desktop. We can view and open the file when we go in her c:sharpdesk desktop file. We just...
You can also right click on the file and left click on "open with" and then select choose program. In the list of programs choose Adobe reader and then at the bottom of the window put a check mark next to "always use the selected program to open this kind of file"
This should take care of the issue
Jan 22, 2010 | Sharp AR-M205 Copier
Network scanning issue with sharp arm205
This machine can only scan across a network when the Sharp network box is installed and 512mb extra memory is installed in the copier
May 23, 2009 | Sharp AR-M205 Copier
I need help regarding our scanner. Thanks.
The problem is you don't have enough memory to scan A3 in 600dpi. You can either try lowering the dpi or add additional memory.
May 20, 2009 | Sharp AR-M205 Copier
Mar 19, 2009 | Sharp AR-M205 Copier
Code: E7-10 on Sharp AR-M237
Your lsu or laser scanning unit is deffective that's why E7-10 appears. it should be replaced
Mar 11, 2009 | Sharp AR-M205 Copier
Sharp ar-m205 error code E7 11
Feb 28, 2009 | Sharp AR-M205 Copier
Dec 18, 2008 | Sharp AR-M205 Copier
Sharp AR-M205 Copier Logo
43 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
