Question about Bosch Washing Machines
Error code 93 on my Bosch front loading washing machine
Unplugged and no progress
    Problem Solver:
  • 13 Answers
What is the machine type?
Posted on Nov 26, 2014
  • 209 Answers
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Posted on Sep 09, 2007
canbruce75
  • 1776 Answers
SOURCE: F35 error code on a kenmore Elite front loading washing machine
This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Posted on Sep 09, 2009
57 varieties
  • 1653 Answers
SOURCE: I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Posted on Oct 02, 2009
milten1
  • 1304 Answers
SOURCE: what does the code 5d mean on my washing machin???
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
Posted on Oct 20, 2009
SOURCE: bosch washing machine error code
what does F'18 means?
Posted on Mar 06, 2011
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Error code 93 on my Bosch washing machine front loader
Sorry,I cannot find code #93 for Bosch washer. I looked a LOT,too.
Nov 11, 2014 | Bosch Washing Machines
I have a 300 Series Bosch front load washing machine witn an E:27 error message. I can't get it to reset. What is wrong?
Do you know what the E:27 error code means? Different machines have different codes. I am not a bosch expert, but if you provide the complete model # to your machine chances are good that i can find the meaning of that error code and maybe a whole lot more.
Jan 06, 2013 | Bosch Washing Machines
How to check error codes on Bosch Nexxt 6400
Hi there:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Jan 29, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Hi there:
Error code E:01
Hi and welcome to Fixya, The E01 error for your bosch indicates a door lock problem has been detected at the control board. Insure the door is closed tight, turn your breaker off or unplug the washer for a couple of minutes and retry. Let me know what happens, ultimately it may be a faulty lock assembly, a loose wire harness etc. but we'll cross that bridge when we get there...if necessary. I'll watch for you to respond with the result's. Good luck. Macmarkus :)
Jun 07, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washer will not open, drain or spin.
if the error code is SE it needs 2 be manually drained
Apr 16, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
37 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
