Question about Canon imageRUNNER 3025N Cassette / Bypass Separation Roller Genuine
It says paper has jammed after photocopying 3 or more papers
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 99 Answers
You may have a small piece of paper stuck in the wheel area that you may not see. Dust can cause this too, like ink.
Posted on Nov 12, 2014
PA8558
  • 28 Answers
SOURCE: i860 False Paper Jam Message
Check the back of the printer. There should be door at the bottom. Your paper jam could be there.
If this helps you, please rate me. Thanks, Patty
Posted on Dec 30, 2007
SOURCE: false paper jam error message
get a lighter and set it on fire.
Posted on Oct 23, 2008
SOURCE: problems with paper feeder-wont feed through-chews up paper
I HAD THE SAME PROBLEM A MONTH AGO. I LOOKED WHERE THE PAPER LOADS AND THERE WAS A PAPER CLIP JAMMED IN THERE. I HAD A HECK OF A TIME GETTING TO IT, BUT I DID. AND IT WORKS FINE. MAYBE SOMETHING IS THERE.
Posted on Feb 01, 2009
digitalhubz
  • 109 Answers
SOURCE: My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Posted on Oct 21, 2009
  • 63 Answers
SOURCE: paper jam (e3) BUT no paper jam
make sure you open all check points, if yours has a rear feed through, look in there also. it only takes a tiny piece of paper to cause it to say that. use a flash light, have had to use one to find several that way.
Posted on Feb 03, 2010
Paper jam when there isn't one
i need software driver for Ineo Develop Photocopier
32 + 64 bit: OS windows 7 & 8
Jul 02, 2013 | Office Equipment & Supplies
My canon MP287 cant print.black when photocopy. The paper also started to jam so it cant print. what will I do?
When there is a paper jamb make sure the whole piece of paper is removed because any tiny pieces of paper that are left behind will cause further paper jambs.
If the paper does not feed through the printer correctly then the rubber rollers are dirty/sticky. Clean the rollers with methylated spirits to stop the paper from sticking to the rollers.
Mar 02, 2013 | Office Equipment & Supplies
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Paper not going through and when it does it jams
Clean the entire printer of old paper, and bits and paper. You will be surprised how often a little piece of paper is stuck somewhere. Buy a bright LED torch, keep by printer ,so can check carefully.
Try a thinner paper, 70gsm. Thicker paper jams more often.
Buy fresh pack of paper. Paper gets wet. Old paper jams.
If older printer then the rollers might be dirty and sticky. Can use a cotton bud to wash with alcohol. Otherwise put your paper in a closed container and keep it dry. If damp/humid , then the paper gets sticky.
I am a finance whistleblower and have used some 10 printers and 1 10,000$ photocopier, all worn out. Sometimes just got to go buy a printer.
Buy the most cheapest printer. When it dies, go buy another. That way never loose money on big scan/print/fax dog printers. Use a local fax company and photocopy company - let them wear out their printers.
God bless John
May 04, 2011 | Office Equipment & Supplies
Canon NP 6650 photocopier. Begins to pick up paper, stops and gives message about jammed. Checked path and see no paper or parts of paper. Need service manual.
1)jammed issue.
2)can u try to make copies by using stack bypass or other paper deck see whether u hav the same fault.
3)or flip over your paper and put it in the paper deck again .Fan the paper ,it could be high moisture and static on the paper.
4)clean the paper dust from the pick up unit with damm cloth.
Sep 04, 2009 | Canon Office Equipment & Supplies
Consant paper Jam - Canon 1600 photocopier
Try to clean the rubber parts. Probably these are filled with paper dust.
Jul 22, 2009 | Canon ImageRunner 1600 Copier
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
After printing a page, 2 red light signals show and doesn't print anymore until after certainparts of the copier were opened and then closed. When the swiych in turned on again, it copies only 1 and then...
1)check properly if there is no paper jam, make sure all jams have been removed
it this doesn't work
2) Remove the paper in the paper tray and replace with papers tha do not have folded edges
Make sure you are not using a paper that cannot run smoothly through the photocopier (too light or too hard)
3) Also check if some papers are stucked under the paper tray.
Apr 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
Konica minolta bizhub 162 photocopier paper jam problem
tenho um problema de paper ja open 1st side cover,m o que fazer
Sep 02, 2008 | Office Equipment & Supplies
Canon imageRUNNER 3025N Cassette / Bypass Separation Roller Genuine Logo
22 people viewed this question
old marine
old marine
