Question about Sewing Machines
I have a singer sewing machine 247 . I broke the needle and have replaced it now the bobbin will not turn.
  • Sewing Machines Master
  • 626 Answers
CHANGE THE NEEDLE. TAKE OUT ALL OF THE BOBBIN CASING. CLEAN IT AND PUT ONE DROP OF OIL ON THE RACE (THE INDENT AREA THAT EVERYTHING RIDES ON AND CAN'T BE REMOVED). LOOK FOR A BROKEN NEEDLE PART AND THREAD AND ANYTHING THAT SHOULDN'T BE THERE. PUT EVERYTHING BACK. TURN THE HAND WHEEL TOWARDS YOU AND OBSERVE IF THERE IS ANYTHING TOUCHING THE NEEDLE. IF THERE IS THEN THAT WILL NEED TO BE FIXED.
Posted on Nov 13, 2014
SOURCE: I need to load the bobbin for my singer 247, I have no manual
I am a veteran seamstress and I may be able to help you. it sounds as though you just have the wrong needle in the machine or the needle is in backwards.. Machine needles are different lengths according to what machine it is. The needle could also be dull on the point. Try this and see if it helps. Also your local sew shop can help you no charge if you just go in and talk with them. The techs enjoy helping for the most part I have discovered.
Posted on Jan 08, 2009
  • 69 Answers
SOURCE: Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Posted on Feb 12, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 16 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
  • 1788 Answers
SOURCE: I have an old singer sewing machine 401A. The top
You can download a manual for $10 at www.sewingmanuals.com and it should help you. A couple of suggestions though, is your needle inserted correctly? Flat side facing the rear of the machine, fresh needle? Threaded correctly on top and bobbin area? Is your thread good not too old and the same type in bobbin and top? Did you leave a long enough tail in the bobbin thread? 3-4 inches which you hold with your left hand. Is the thread in the bobbin unwinding the right way? Are you turning the handwheel towards you, not away from you at least two revolutions or until you see the thread loop? Try these suggestions, and I am sure one will work unless your timing is off and it needs professional service.
Posted on Sep 20, 2010
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
Ive got a singer sweingmachine 247 model no when i put the bobbin in the bobbincasing with tread and guide so the needle goes down to bring bottom tread up nothing happens it doesnt feed it to come up i...
try changing the needle
try rethreading the machine, make sure the presser foot is in the up position
make sure the bobbin is turned correctly in the bobbin case,, counter clock-side
also could be a timing problem
Dec 22, 2014 | Singer Sewing Machines
I have a singer 247 I broke the needle and have replaced it . Now the bobbin will not turn I have taken it apart and still doesn't work if you could help me fix it I would appreciate it
Most likely the needle was broken when a piece of cloth was under the machine right , this means that the needle was slightly bent while it went down to pick up the lower thread , in most of these cases it damaged something fornm the bottom spool.....better check carefullyfor marks and VERY genrly with a new needle in place utrn by hand and see feel where it gets stuck...then replace part or bring to shop to fix ...
Nov 11, 2014 | Sewing Machines
Sewing machine needle will not pick up bobbin
Hai, You can use (elastic) big size new quality needle. Then last 10 or 5 steps off the machine movie the handle.
Mar 23, 2014 | Singer 5400 Sew Mate 60-Stitch Sewing...
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Needle broke and i changed with the same number now it is not picking up the thread and does not stitch
you said the needle broke, did you check in the needle plate where the feed dogs are if there was any needle fragments
also check in the bobbin area for needle fragments, take the bobbin case & bobbin out & clean the area
Oct 21, 2010 | Singer 8280 Mechanical Sewing Machine
Thread from the needle wraps around the bobbin case and knots
hi! there,
wrong set up made this thing goes wrong,well
its good things to go to internet, on address
type www.youtube.com type on search
box type "sewing macnine" there some
instruction follow specielly set thread and
bobbins and some otrhe sewing feature that
you can learn.have a nice day dont forget to
rate me, thank's
Apr 10, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Jan 08, 2009 | Singer Sewing Machines
Singer 7422 bobbin thread bunching up
I assume you checked to see there are no needle bits in the bobbin case holder.
Without looking at the machine it is difficult to diagnose the problem. It could be any one or a combination of problems, timing, needle bar height, damage to the hook and base etc.
I strongly suggest you have it looked at by a sewing machine tech.
Mar 29, 2008 | Singer 7422
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
