Question about Grohe Home
Our Grohe 36023 no longer works. It is flashing error codes 11 and 13 and 01. The water is way too hot and then it conks out.
2 Suggested Answers
  • 56 Answers
SOURCE: Shower will not get hot enough
i have no experience in fixing showers however mine once did this when i remodeled my bathroom so i called one of the guys that was workin on it and he told me that he had takin something out what looked like a gasket and said it was a scald preventer and from then on my shower has been fine hope this helped
Posted on May 19, 2009
Only cold water coming from Grohtherm wireless 36023
There are multiple possibilities:
- the power to the main control could be off (seems unlikely if you can turn the water flow on and off)
- the thermal element that heats the water could be burned out (may not be a problem if this is only a mixer unit and relies on external hot water supply)
- there could be a problem with the solenoid that opens to allow hot water to flow through the unit
- there could be either no hot water getting to the unit or blockage so that hot water will not flow through to the mixer
Start by making sure there is power. Then you may need to disconnect the hot water supply (after turning it off at the source) and then check to see that hot water will flow. If you get hot water to the unit then there is something internal keeping the hot water from mixing with the cold.
Oct 28, 2014 | Grohe Home
GROHE WIRELESS ERROR CODE 20 UNDERSTAND THAT THESE
its called a flow switch it is in the pump can b replaced when u turn on it pumps air in valve shuts replacemnt will sort it
Oct 02, 2013 | Grohe Grohtherm Thermostatic Rough-In...
I have a Grohe shower system that has the temperature control it was working fine and now the water only comes out luke warm. the handle goes from 65 degrees to 110 degrees. I live in a older highrise...
WEll, the question is do your sinks have water that is hot enough? If no, perhaps your water heater is set too low. If yes, many shower controls have hot limiter and if you pull the handle, often there is a spline assembly that stops the travel from going hot, adjust to allow more.
Dec 13, 2010 | Grohe Home
Little hot water flow with Grohe 1000 grohthern
Yes it sound like you have blockage in the mixer .
Jan 17, 2018 | Grohe Grohtherm Thermostatic Rough-In...
Grohe valve Grohtherm Thermostatic Rough 34-126 I turn the mixer to full hot but the temperature remains tepid. All the other faucets in the
The thermostatic stop is set too low. Havent set a grohe before but most other thermostatic shower valves work similar. pull off the handle(however a grohe handle comes off . . ) there should be a notched ring or stop which keeps the handle from going all the way hot. pull out the ring and turn it a few teeth hotter put back and reinstall handle try water temp and adjust again if necessary.
Jan 23, 2010 | Grohe Grohtherm Thermostatic Rough-In...
May 19, 2009 | Grohe Rainshower Shower Head -...
Home Logo
43 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
