Question about Kitchen Appliances - Others
My motor arm / pin does not reach the kettle to rotate the arm, kettle hangs crooked. Suggestions?
The Kettle Agitator gets stuck. Appears the Rotating Center is Wobbly. . .
The motor output shaft bushing might have came loose I have seen where it falls out of the motor and the shaft becomes real wobbly and it will cause excessive wear in the kettle cross bar bushing too. also make sure the cross bar and lid assy. is not come loose from the kettle.
Feb 27, 2016 | Star Manufacturing Star G12-Y - Galaxy...
Windsheild wiper won't turn off
The electrical mechanism has a rotating arm with a wiper contact, whose objective is to prevent the wipers stopping in the middle of their travel, thus this small wiper contact continues to supply current to the wiper's motor until they reach the end position. From time to time, the wiper (or the electrical track support) rotates out of proper alignment, and just keeps the winshield wipers running. you need to disassemble the motor of the wipers, inside there is a small arm with a contact point, it need to be realigned. It is not difficult, but some dexterity is needed to be able to properly reassemble the motor.
Nov 17, 2013 | 1992 Dodge Spirit
How do I get the agitator rotate
The motor in the top of the machine should rotate the gear sticking out of the top of the cabinet when you turn the switch on. This gear should connect with a gear on the top of the shaft that sticks out of the kettle when the kettle is in the correct upright position and turning the stir rod.
Make sure the kettle is installed correctly, and the switch is in the on position. If the motor is not turning with the switch on, it is broken and should be returned to store if possible.
There are no repair parts for this brand popper, and they cannot be repaired.
Sep 03, 2013 | Nostalgia Electrics Helman Group CCP-510...
The front wipers of my 97 passport stopped working
Hi Facebreaker, With a name like that do really expect someone to reach out and help you? Well there's one born every minutes so I guess I will! take off the wiper arms by loosening off and then removing the nuts. Leave them attached but with enough room to jiggle them up and down until they become loose. Once they have, remove the nuts and arms. Take of the cover and locate the wiper motor. Refit the rotating arm, making sure to sync it for self parking and then fit back the rotating arm of the wipers. If the nut has been lost, fit a replacement self locking nut, test it and then refit everything. assembly is the reverse of stripping Regards John.
Mar 29, 2012 | 1997 Honda Passport
Have a problem with a Breville Classique kettle,model number jk91. It does not switch off automatically. Any suggestions please? regards Sandra Smith e-mail davidforrest@hotmail.com
Every kettle has a thermostat/thermometer that trips the switch to off when the water reaches boiling point. The solution is not usually something you can do yourself. Your best bet is to consult the manufacturer for a repair/replacement (if under warranty). I recommend that you contact the retailer first as most retailers have an agreement with the maunufacturer to replace most small kitchen items if it's still under warranty and develops a fault.
Jul 06, 2011 | Breville Kitchen Appliances - Others
Replace 2005 CTS left front turn signal bulb
Sorry to reply so late.
It's got to be the same as my 2004 CTS...
Remove 3 or 4 of the plastic pins holding the inner fender. They are located around the lip of the fender opening. The pins are removed by pulling the center cap of the pin straight out about an 1/8" and then wiggle and pull the whole pin out.
Pull the inner fender down and back.
Reach your arm in and grab the socket and squeeze the locking tab.
Rotate the socket counter-clockwise less than a quarter turn, and pull straight back.
Reach your other hand in and remove the bulb by pulling it straight out of the socket. It takes a 3157 bulb
Aug 26, 2010 | 2005 Cadillac CTS
Procedure to change turn signal light bulb on a
Mar 30, 2010 | 2005 Cadillac CTS
Replace turn signal bulb how do i get to it?
Front bulb?
Mar 03, 2010 | 2004 Cadillac CTS
Chevy S-10 1994 Wipers don't work at all...cruise works, turn signals work, but no wipers. Fuse is fine
Park you car in a quite location.
Engine off
Turn wiper to high and listen for the motor rotation noise near the firewall (near the bottom of the windshield)
If you hear the motor rotation noise and the wipers are not moving then it's the linkage and/or the motor clutch.
Get to it ASAP. A loose bolt connection can damage the linkage arm or clutch.
It's time consuming to replace these hard to reach park.
Nov 11, 2009 | 1994 Chevrolet S-10
Drum will not spin. The belt is not broken but is hanging lose
If the motor is working...Shut off the power to the dryer, reach inside the drum and try to rotate the drum 1/4-1/2 turn. Sometimes the motors get dead zones in them and this will help move it out of the dead zone
It could also be the drum rollers that need lubrication or replacement, if they are not rotating it would not allow the drum to spin.
I hope this helps
Oct 02, 2009 | Kenmore 73952 Gas Dryer
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
