Question about LG LSC27910TT (265 cu ft) Side by Side Commercial Refrigerator
How do I fix the water dispenser on my LG refrigerator?
The water dispenser quit working so I replaced the filter but it is slow after initially splattering both water and air.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 99 Answers
Drain it and clean it or try flushing it to get all of the air out.
Posted on Nov 12, 2014
    Sergeant:
  • 311 Answers
#1 cause is the water filter. There may be other blockages in the line. Change the filter one more time and allow the air to purge out of the line. You will make a mess.
Water dispenser running slowly
Hello Cynthia;
My name is Peter. I am a retired field service refrigeration technician.
You have a water pressure problem. You need at least 60 PSI water pressure to open the solenoid valves. I suspect you are getting small ice cubes.
If you have well water you are not going to get the pressure for fully dispenser flow.
I have experienced bad water filters. One time our techs received a large shipment of bad water filters. Remove the water filter and test the water dispenser.
With low water pressure you may not want to use a water filter
Dec 08, 2014 | LG LFXS24623S 24.0 cu. ft. French Door...
Fix the water dispenser on my LG refrigerator that is slow.
Hello Frank;
The are 2 possible causes:
1.) If both your water dispenser is slow and you are getting small ice cubes then you either have a bad water filter or a water pressure problem. You water shut off valve can deteriorate internally. This is a common problem.
2.) If your ice cubes are of normal size, then either your water solenoid valve is plugged up or the water tank in your fresh food section is partially frozen restricting the flow. I would bet on a bad solenoid valve.
You can Ohm the solenoid which should read '0' if it is good.
Nov 12, 2014 | Refrigerators
Water dispenser very slow
Check the filter and replace if necessary.
Oct 26, 2012 | LG LMX25981ST Four-Door French Door...
Replaced Water Filter - Now Slow Water Dispensed
If its should solved with an original spare part again then there could there be a marketing technical patent on some materials.
Aug 26, 2017 | LG LSC27931S Side by Side Refrigerator
Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
May 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Low flow from water dispenser
hi, this can be because of the filter. when the water is flowing threw the filter, it is sent threw many channels inside the filter before it reaches the dispenser. this slows it down a bit. this is quite normal but, if it's slowed down to a dribble, i suspect a water valve malfunction or you may need to change the filter.
Mar 15, 2009 | GE GSH25JFR Side by Side Refrigerator
Water dispenser is working very slow the water is flowin very slow.
is the s water holder frozen?
Look behind the lower left prodcue box
if not it could be the despenser valve not
opening all the way
Is the ice maker working OK?
Aug 04, 2008 | LG 22.4 cu.ft. French Door with External...
Water dispenser quit working
you will need to check the water inlet valve in the rear of the refrigerator it is a dual valve one side for IM the other for the disp.
Jan 30, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
LG LSC27910TT (265 cu ft) Side by Side Commercial Refrigerator Logo
182 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
