Question about RCA L26WD26D 26 in. LCD TV
I have a RCA L26WD26D tv that the screen has turned a dull white and that's it is there a part change I have another one like it with a broken screen but all the parts in it should be good how
I have a RCA L26WD26D tv that the screen has turned a dull white and that's it is there a part change I have another one like it with a broken screen but all the parts in it should be good how would you start this? wayne
    Top Expert:
  • RCA Master
  • 75,178 Answers
Sounds like T'Con board fault. Contact any service technician.
Posted on Nov 12, 2014
tlm931
  • 273 Answers
SOURCE: RCA L26WD26D LCD TV:Turn on,turns itself off,then
it will either be a defective tact switch on the control buttons on the set
or a main board causing this problem it it still has warranty you would contact RCA and get the number of a local servicer to assist you with this problem
Posted on Nov 09, 2009
dave1645
  • 834 Answers
SOURCE: I HAVE A LINE THAT GOES THROUGH THE SCREEN FROM
the LCD panel has failed but i know of no one that has a replacement panel for that model get the genaric number off the panel on a white sticker and do a search .maybe some one will have a good pullout
Posted on Dec 23, 2009
  • 1121 Answers
SOURCE: dvd stuck in RCA widescreen tv
There are two things you can try to correct this problem on your TV/DVD combo unit:
  • If you're using the remote control, press the DVD/TV button first to make sure the remote control is in TV mode.
  • If you're trying to use the buttons on the front of the unit, unplug the TV/DVD for two minutes, and then plug it back in. Press the ON/OFF button and try again.
Posted on Feb 20, 2010
Testimonial: "the information provided WORKED !! TNX MUCH"
  • 277 Answers
SOURCE: 32" RCA white vertical "Hazing" that eventually clears up
daniel143962
Take you unit to a service center and ask them to fix it. They won't be able too, but ask anyawys. When they tell you they can't fix ask them for the work order and then call 1877-297-8391 and they will help you
Posted on Jul 21, 2010
jdvillanueva
  • 2098 Answers
SOURCE: I have a RCA L26WD26D Flat Screen TV. When you
Hi coefremont,
This is an indication of out-of-regulation in the power supply section. The very common caused of this fault is the leaky electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit.It needs a little warm-up to make itself stable but the symptom will get worst like what you've experienced right now. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Your unit will back to normal again if the leaky capacitor is isolated.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 09, 2011
When you turn on my TV, the screen is completely white. No sound, no picture. I've unplugged and powered off but the screen still stays white.
It sounds that the main digital processor board has failed. Contact any service technician, before make it sure.
Aug 22, 2013 | RCA L26WD26D 26 in. LCD TV
I need the code to get rid of the region code error on my RCA L26WD26D
I had exactly the same issue, and after a week of searching the web for the answer to this question. I posted a pdf of the page from the service manual that helped me fix the issue here: http://www.highdefjunkies.com/showthread.php/1817-The-Official-quot-Service-Menu-Access-Codes-Request-Thread-quot?p=353717#post353717
To fix mine, all i did was turn the volume on the tv to zero, then on the tv set itself, hold down the volume down button and on the remote control hold the number 4 button down both at the same time for 2 seconds. The screen will say "initialization of factory dvd data." and my dvd player started playing my dvd's no problem. I wasn't able to set the region code to a specific number like some people need, but maybe the answer to that question is some where else in the manual I posted above. I've spent too much time on this already :-D Hope this was a help and good luck!
Sep 08, 2011 | RCA L26WD26D 26 in. LCD TV
I have an RCA L26WD26D TV/DVD combo. It work great, until one day I turned on and there was no sound and a white screen. What can I do to repair my tv?
A white screen means that you are not getting any signal to your lcd screen. That is the job of the T-con board. The T-con board is located on the backside of the screen attached to it. You can get parts from www.interliquidparts.com
Jun 08, 2011 | RCA Televison & Video
I just turn on the TV and I see double on my tv
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 03, 2011 | RCA HD56W66 56" HDTV
It has a wavy line through middle of screen with like white light shining through it in three places. I do not think it is the convergence, when I go to convergence screen the red and blue will move but...
  • Screen looks 3D
69189a5.pngSOLUTION
Apr 30, 2011 | Mitsubishi VS-55609 55" Rear Projection...
I HAVE A LINE THAT GOES THROUGH THE SCREEN FROM TOP 2 BOTTOM ON MY RCA L26WD26D
Dec 22, 2009 | RCA L26WD26D 26 in. LCD TV
RCA L26WD26D LCD TV:Turn on,turns itself off,then on,then off, then on, then off.
Nov 09, 2009 | RCA L26WD26D 26 in. LCD TV
RCA LCD TV 26 screen turns white, no sound no nothing
You have a blown fuse in the power supply. It does not look like a fuse.
It is near the top of the board and is labeled as 1.6 amp. It supplies 12
volts to the main board (via q422). A 2 amp fuse should be a fine
replacement.
Sep 04, 2009 | RCA L26WD26D 26 in. LCD TV
RCA L26WD26D
sorry dear...just got disconnected
Feb 29, 2008 | RCA L26WD26D 26 in. LCD TV
RCA L26WD26D 26 in. LCD TV Logo
106 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
