Question about Refrigerators
Fix the water dispenser on my LG refrigerator that is slow.
The water quit working and I replaced the filter. Initially there were some air bursts and water splatters, but then it went to continuously slow; a trickle.
  • Refrigerators Master
  • 744 Answers
Hello Frank;
My name is Peter. I am a retired field service refrigeration technician.
The are 2 possible causes:
1.) If both your water dispenser is slow and you are getting small ice cubes then you either have a bad water filter or a water pressure problem. You water shut off valve can deteriorate internally. This is a common problem.
2.) If your ice cubes are of normal size, then either your water solenoid valve is plugged up or the water tank in your fresh food section is partially frozen restricting the flow. I would bet on a bad solenoid valve.
You can Ohm the solenoid which should read '0' if it is good.
Posted on Nov 14, 2014
  • 11 Answers
SOURCE: Water flow decrease on refrigerator dispenser
You might have calcium deposits in the supply line.You can unscrew the line from the fridge and turn on the water to see if you have good flow. Have a bucket or pan handy. Let it run for a minute. If it checks out ok then the problem might be in the line attached to the fridge. Those usually come off fairly easy. If so take that off and see if its clogged. You can also check the valve where the feed is connected to the main water.
Posted on Apr 18, 2009
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
Greg20
  • 149 Answers
SOURCE: Whirlpool ED22PE refrigerator in-door water dispenser very slow
remove the saddle clamp that some idiot put on the supply line under your sink and splice in a real "T" with a real cutoff. hopefully the saddle clamp is past your main valve and not before it or you'll have to turn off all your water first.
Posted on Jun 11, 2009
woodchuck789
  • 4070 Answers
SOURCE: Water dispenser does not work on my lg
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad. GE makes a heater that will prevent this from happing again. The part number for this heater is WR49X10173.
Posted on Jan 23, 2010
SOURCE: My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Posted on Feb 13, 2010
How do I fix the water dispenser on my LG refrigerator?
#1 cause is the water filter. There may be other blockages in the line. Change the filter one more time and allow the air to purge out of the line. You will make a mess.
Nov 12, 2014 | LG LSC27910TT (265 cu ft) Side by Side...
Water dispenser very slow
Check the filter and replace if necessary.
Oct 26, 2012 | LG LMX25981ST Four-Door French Door...
My water dispenser is leaking. I've replaced the filter and checked the dispenser if it's stuck but it's not. What should I check or replace? Thanks
You models has a tubing coil as a water tank. Once you changed the filter air bubbles remained in the system. Slow leaks or drips from the water dispenser can be the result of air trapped in the water line and will usually occur just after replacing a water filter. When the filter is changed, a large amount of air enters the system and needs to be removed by running water from the dispenser until all the air pockets are gone. Another reason is the water valve itself may not be sealing when closed allowing water pressure from the supply like to work its way into the dispenser water line. This is a less likely reason, but you should be aware of this possibility when diagnosing your own problem. Thanks, Sea Breeze
Jan 28, 2010 | GE GSS20IEP Side by Side Refrigerator
Replaced Water Filter - Now Slow Water Dispensed
If its should solved with an original spare part again then there could there be a marketing technical patent on some materials.
Aug 26, 2017 | LG LSC27931S Side by Side Refrigerator
ice maker?
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Water dispenser quit working
you will need to check the water inlet valve in the rear of the refrigerator it is a dual valve one side for IM the other for the disp.
Jan 30, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Kenmore Side by Side Refrigerator Model #106.50544001
It's time to replace the dual water inlet valve (the part the water line connects to). A bit of sediment or other fine object can get in the seat or the material itself can deteriorate and allow a tiny amount of water to pass up to the icemaker.
Jan 04, 2008 | Whirlpool GR2SHWXPB 21.7 cu.ft. Top Mount...
Slow water flow
dadcanfix. There are two possibilities here. One could be the water valve itself, clogged or not seating or opening properly. The second would be the water tank on the refrigerator side, partially frozen. I believe they have a kit now with coiled tubing that replaces that tank because of the trouble they had with it. Remove the refer drawers and take a hair dryer and go over the tank lightly. See if that improves the water flow. Catriver..post back.
Mar 20, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
180 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
