Question about Dodge 1997 Ram 1500
How do I reset abs and brake light on 1997 dodge ram 1500. Replaced speed sensor. Also unplugged Pulse control box under dash. Light is determined to stay on. Please help
Have replaced brake booster, master cylinder, brakes
    Sergeant:
  • 311 Answers
Some cars/trucks run the ABS power through the brake light bulbs!
Does brake light and ABS light come on separately,key on,engine off?
Be sure that the parking brake switch is not bad.
The brake light should flicker/get brighter/dimmer when actuationg the parking brake.
Also,defeat the low fluid warning sensor.Defeat the pressure differentail switch.
I know some MFRs make both lights come on when either system fails.
Check for signal FROM the sensor at a wheel Use A/C voltage mode. I have spun the undriven hub with an electric drill to see A/C output.
Please note that the brakes will work OK but you not have ABS function.
See if you can get the brake warning light out,separately.
Posted on Nov 12, 2014
2004 Dodge Ram 1500 pickup speedometer and odometer quit
I am having the same problem. I replaced the speed sensor on the rear diff. and the problem went away but when i started it the next day the problem came back. If you figure it out let me know.
Oct 19, 2009 | 2004 Dodge Ram 1500
2003 dodge ram 1500 abs & brake light came on. also cruise does not work. any suggestions
Problem: I have a 2004 Dodge Ram 1500 5.7 L HEMI. My ABS and Parking Brake lights were illuminated, and my speedometer needle would "bounce". Also when sitting at a stop sign or just sitting idle, the engine would stall, and often times stop running.
Solution: After long research on this problem, I decided to dig in and try to find the problem myself. I replaced the Rear ABS Sensor
($35) that's located on top of the rear differential. Still no fix. I then unplugged the ABS Controller (or Module) that's located directly behind the battery (You should see the metal brake lines running into the top of it.) When I unplugged it, I noticed LOTS of moisture in the plug. Using an air hose, I blew out the water and let it dry good. When I plugged it back in, and hooked the negative battery terminal back up THE PROBLEM WAS SOLVED!! Simple fix. Hope this helps.
Sep 30, 2009 | Dodge Pickup Cars & Trucks
98 dodge ram 1500 4x4 5.9L The engine light is on, the antilock brakesystem light is on. speedometer and odometer do not work. The brake light is also on but the truck still stops just fine. im guessing...
Hi, Autozone will scan your vehicle for free 1997 and newer vehicles. Your brake fluid being low will also make the brake light go on. Ihope this helped you out. Good luck, .....MIKE-
Sep 29, 2009 | 1998 Dodge Ram 1500 4WD
Just my speed guage does not work and abs light and parking brake light stay on on my 99 ram 1500
you have an code stored in the abs module.likely a bad rear wheel speed sensor.as it runs the speedometer.check wiring to the sensor.it is located on the top of the rear diff housing.hope this helps.
Sep 09, 2009 | 1998 Dodge Ram 1500 4WD
Random lights coming on in the dash and stalling occasionally
See if you can find out if there is a code for the check engine lite and the abs, those can be related if the speed sensor located on the top of the rear axle is intermittantly failing. That sensor sends the speed signal to the pcm and the abs controler witch will also turn off the cruise control.
Feb 17, 2009 | 2001 Dodge Ram 1500 Truck 2WD
2002 dodge 1500 sport speedometer or cruise control
The brake and ABS light both come on when you are receiving no speed signal. Most likely the speed sensor in the top of the rearend is bad.
Feb 16, 2009 | 2007 Dodge Ram 1500 Quad Cab Sport
Abs and brake lights both stay on
most likiely is a wheel speed sensor for the abs system that hasf ailed
Feb 01, 2009 | 2004 Dodge Ram 1500
I have 1998 dodge ram my abs and brake light came on
IIRC, the speedo reads off of the sensor in the center section of the rearend. Also controls ABS. Hope this helps!
Dec 24, 2008 | 1998 Dodge Ram 1500 4WD
Dodge 1997 Ram 1500 Logo
131 people viewed this question
Top Dodge Audio Players & Recorders Experts
Betty Pearl
Betty Pearl
Level 1 Expert
Jeff Brewster
Jeff Brewster
Richard Warren
Richard Warren
Are you a Dodge Audio Player and Recorder Expert? Answer questions, earn points and help others
