Question about Refrigerators
I have a french door Dometic in my 2006 Tiffin RV. It is not working and service tech says it is rusty. Can it be repaired?
The coach is in Myrtle Beach while I am in Maryland for surgery. I am hearing from the tech but have not seen the problem. Should a'06 Dometic last longer?
    Sergeant:
  • 311 Answers
An '06? Really? Call an RV service center to see if parts are available. NOT the same place that repair person came from.
You will need a model and serial number B-4 you call them.
Posted on Nov 12, 2014
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
SOURCE: Water dispenser quit working on GE Profile French door 'frig.
The dispensers could be clogged with mineral deposits. If you look in your care manual it talks about a water vinegar solution that you pour into the top of the despenser, let sit, and then drain it through the back. I had a similar problem and it was because some of the water that was sitting in the top of the unit(where the gallon jug sits; under the black think) was full of frozen water which was blocking the water dispenser.
Posted on Jun 19, 2009
VtToolMan
  • 704 Answers
SOURCE: I purchased a used RV with a Dometic RM2652
Give this company a try, they have both new and used parts available and can provide most anything for the Dometic fridges.
http://gasrefrigeration.net/
Hope you find this very helpful and best regards!
Posted on Aug 08, 2009
  • 4793 Answers
SOURCE: Dometic 3 way RV ...the igniter strtrer just keeps
sounds like thermocouple needs replacing..easy job ? if you know what to do....
Posted on Feb 09, 2010
  • 394 Answers
SOURCE: our rv has a dometic rm2600 fridge that smells of
Sorry to give you the bad news. The ammonia smell is the the refrigerant
leaking out. Dometic uses ammonia that is heated and then condensed to cool. It will all leak out and quit cooling.
The fridge is wrecked. There are shops that rebuild the units. Beings as ammonia is corrosive one must assume there may be other leaks ready to appear. There are RV salvage yards that sell good used units.
Again Sorry for your loss.
Posted on Apr 27, 2010
Why won't Microwave door stay shut?
We are having the same problem. Seems like latch spring is broken. We can not find any parts for this. Dometic is 3 yrs. old so no warranty. No service for it either. Keystone really took us on this
Jul 06, 2014 | Dometic DOTRC17B RV Microwave/Convection...
Does not cool the coach enough
It is one of a couple of things. Either the air conditioner4 needs recharging, the compressor is not coming on, or the ac unit is to small for the coach.
Aug 04, 2011 | Dometic Rooftop RV Air Conditioner
I have a dometics air system in a 2006 fema camper the air works but when it cuts in the silver box in the ceiling off it will not restart it just makes a clicking noise
Sounds like the circuit breaker for 120V side of AC is tripping due to high amperage draw, which could be caused by weak breaker, faulty compressor, faulty start capacitor, or even improper wiring to list a few things. You should have it checked by a qualified RV tech or AC tech to determine which is the cause.
May 12, 2011 | Dometic Rooftop RV Air Conditioner
What are the procedures to employ to prevent problems from arising;=preventative maintenance??i have a dometic 15k ducted a.c on a 1997 airstream fifth wheel.
keep the unit clean of debri and dirt in condensing coil . to accomplish this a water hose will work in most cases remove the cover from atop the unit an gently spray the coil take care not to get water into the ducting system and into your coach.Dont do this with unit running disconnect power and dont put unit back into service until dry good luck
Jun 18, 2010 | Dometic Rooftop RV Air Conditioner
RM2652 Refrigerator: I have a DM2652 model Dometic RV refer. It is leak...
Dometic Voluntarily Expands Refrigerator Recall
Dometic recently expanded its recall on a population of two-door refrigerators. The original recall included some two-door refrigerators manufactured between April 1997 and May 2003. The new recall focuses on models manufactured between June 2003 and September 2006.
To see if your unit is on the recall list & what to do, try the link below.
If your unit is on the list, DO NOT run your refrigerator on propane until the kit is installed
http://www2.dometicusa.com/recall.php
May 18, 2010 | Dometic RM2652 Refrigerator
Dometic a/c on fifth wheel with comfort controls
First lets address the heating issue. These are not furnaces but are known as "Chill Chasers" and are not designed to "heat" your RV Attempting to use them as a whole coach heater will burn them up in short order.
Your A/C sounds like the coils are freezing up. There is a small probe that is placed into the coils. you can see it from under the unit if you remove the interior cover - a little 1/8" in dia. silver piece flattened on one end to slide between the coil fins with a wire going back to the control box
It may have fallen out
Sep 29, 2009 | Dometic Rooftop RV Air Conditioner
Mal functioning thermostat on duo therm model 620215
Ok;
Upgrade kit Part# 3307713.010
Price is 274.75 Plus shipping
Can be purchased from any Dometic dealer or I have an ad on this site. Coach Tech RV
Thanks for using Fixya
Jerry
Mar 29, 2009 | Dometic Rooftop RV Air Conditioner
Condensation
First clean this up ., and add a drain tube to the bottom of the coach!
Sep 08, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Top Freezer RV/TT Refrigerator
You have a switch inside the door. Turn it on this actually keeps the light on inside. This may help with your humidity problem. Also check to make sure the drain out side of the coach is not clogged you should see water coming out
Aug 05, 2008 | Dometic RGE400 Top Freezer Refrigerator
Owners manual
I think you have this in the wrong area. try and repost in the correct one. Thanks
Jan 13, 2008 | Audio Players & Recorders
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
