Question about Bosch Power Box 360 Jobsite Radio PB360S
Hallo my bosh pb360 s not work only the outlet have power
No power on on/off just the outlet
    New Friend:
You blew an internal fuse. There are two glass fuses inside. Unplug the unit, flip it upside down, remove screws and four from roll cage so you can take it apart. Inside you wil see both fuses and will be able to determine which one to replace. Be careful to make sure subwoofer wire is connected before re-assembly!!!
Posted on Nov 24, 2014
Why doesn't it fill or wash?
I had this on a Bosh G500. the fault was the motor start/reverse capacitor was open circuit (10UF 450VAC) the motor buzzed when powered but did not rotate. As a first check make sure the motor/ pump unit is not seized. the rotor should rotate with a little resistance.
the motor has 3 wires, black brown blue I think. If the motor is disconnected and mains applied between either side of the capacitor and the other wire it should rotate. The chosen end of the capacitor will chose which direction it rotates in. Any suitably rated capacitor will do, no need for a bosh special, but it MUST be AC rated, a DC electrolytic cap would heat up and explode!
Follow safe working procedures when working with exposed mains voltage.
Mar 06, 2016 | Bosch Dishwashers
Tip
How to Verify Power from a 110V Outlet
Video about How to Verify Power from a 110V Outlet
  • The first step of troubleshooting a power issue with a machine equipped with a power cord is to verify that the outlet being used is working
    • This video demonstrates a simple method of testing the outlet
  • Make sure that the outlet and appliance have matching plug and receptacle before plugging in
    • Failure to do so could result in injury and/or damage to electrical circuit and/or appliance
  • This procedure is a quick and easy way to test the functionality of a 110 volt outlet
  • Plug in a small appliance such as the fan used in the video and make sure the appliance works
    • If so, you know that the outlet is not your problem
  • You could also use a light, small lamp, or radio for this test
    • Any small appliance that you can plug in and turn on and know the appliance is working
  • This completes our demonstration of testing a 110V outlet for power
on Feb 11, 2015 | Proform Exercise & Fitness
Machine stop running
Make sure all power connections are in place, to outlet and to machine. Make sure power switch in ON.
Check outlet with working lamp to ensure power is coming to that outlet; check panel box to make sure power is coming to that outlet.
Aug 27, 2013 | Singer 2259 Sewing Machine
Hallo, please help, i have a sanyo plasma screen pdp-42v1, it has failed to work, when i switch it on, the green light comes on, then the screen blinks some light and then it goes if and starts showing red...
Step 1 - Remove all 42 screws from back cover. Remove top center screw last, it will help to hold the panel in place during removal of other screws.
  • WARNING!!! DO NOT TOUCH ANYTHING INSIDE. Even after disconnected from the power outlet, the capacitors are electrical components capable of storing electrical energy. Some can have the same energy as a defibrillator and could easily stop your heart. WARNED!!!
  • There are 5 fuses total, make sure to remove them from the holder and check for continuity with a multimeter.
  • If all test Ok, you might need to have the Power board replaced.
http://philhoffmann.zenfolio.com/guestbook.html
Dec 04, 2017 | Televison & Video
Hi, I need some help please! I have a peugeot 406 2.1 td p reg. I've had to put a 1.9 bosh pump on it to bipass the imobiliser. does any one know what order the injection pipes go in. cheers ale
Hi Alex, The firing order is 1-3-4-2. When fitting the injector pump I hope you noticed the match marks for timing. When fitted and aligned the engine will be at TDC firing on one. To identify # 1 on the pump, connect the fuel supply and bleed air from the system and rotate the engine one and three quarter revolutions by hand, having someone watch which outlet ejects fuel when passing TDC completing the second rotation. That will indicate number one piston. Follow the firing order for the remaining three. Regards John
Nov 16, 2012 | Cars & Trucks
The power outlet in the front drivr side by the cup holder doesnt work.
The power outlets get their power from the power outlet relay. The power outlet relay gets its power from fuse #21 in the Power Distribution Center (PDC) in the engine compartment. It is a 20 Amp fuse. If the other power outlet works, it is not caused by the relay or the fuse. You most likely would have a broken wire or defective power outlet in this case.
Jun 13, 2011 | 1997 Plymouth Voyager
I have a bosch pb360 boombox that wont turn on with new batteries and the fuse is fine
There are two internal glass fuses inside the Bosch pb360sc.
If it won't power on, flip it upside down and remove the bottom section of the radio and four of the screws for the roll cage. Once inside you can figure out which fuse is dead and replace it. The Bosch manual is totally useless and does not tell you or indicate that there are any internal fuses. The fuse that runs the 12volt power supply / cigarette style outlet has nothing to do with your radio not being able to turn on/ power up. I guess they want their service partners to be able to jam you for .50 cent fuse....
Apr 07, 2011 | Bosch Audio Players & Recorders
Hallo, i want to get a new hp 513n motherboard because my old one is not working, but i don't know where. Is there some way i can get a new one? if yes. what is the mopdule of the motheboard
Here's a parts outlet selling the 513n motherboard (it's $150):
http://goo.gl/dP7Ee
You might want to check Ebay or someplace else - the whole computer's market value is not worth $150 today.
Mar 17, 2011 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Bosch Power Box 360 Jobsite Radio PB360S Logo
502 people viewed this question
Top Bosch Audio Players & Recorders Experts
wayne-m
Bill Boyd
Are you a Bosch Audio Player and Recorder Expert? Answer questions, earn points and help others
