Question about Garden
Transformer switch pulls in, the pump will not engage, can see arching in switch when I engage and disengage it. Itwas progressivly getting harder to make the switch work
If its the switch can I even get one
    Problem Solver:
  • 14 Answers
Need more info. Transformer switch? Contacts on switch may be burning out.
Posted on Nov 26, 2014
Anti theft system was engaged when a wire arched when I was working on the fans how do I disengage the anti theft system
anti-theft systems are unique, in order to adequately assist you with disengaging your particular system we/I will need your model number of the alarm or the exact veichel it is installed in and rather or not it is a factory system. On another note if there was an "arch" then it is more than possible that 1 or more components were damage, the only solution may be to remove power to the anti-theft system permanently. Some extra information that's unsolicited, you should refrain from working on a veichel you/someone else depends on if your aren't able to adequately take precautions to protect yourself, vehicle and others. Good luck and thanks.
Questions? Just ask! Mr.Mike
Nov 17, 2015 | Cars & Trucks
Clutch won't disengage on my Riding Mower
WITH THE ENGINE TURNED OFF, open the hood and watch the engagement cable. engage mower lever and then disengage the switch sounds happy, possibly the cable is starting to seize up
Apr 19, 2014 | Husqvarna Garden
If you pull the cable to engage the front axel how do you dis engage it
This is done by a switch on the dash, if is an S10. It is electronic switch.
Mar 23, 2014 | 1995 Chevrolet Blazer
Hello, I have a Cub cadet tractor model 2164, and
BEARINGS ARE BAD IN CLUTCH REPLACE THE PTO
Oct 30, 2013 | Cub Cadet Garden
4wd front hub wont disengage
Possible the vacuum bleed-off to the switch you installed isn't allowing it to completely disengage. Pull the bleed-off line from the new switch and see if it works. could be just a tight spot/bent closed in the bleed-off line or the vent plugged.
Apr 04, 2017 | 2002 GMC Sonoma Extended Cab
I have a Spear & Jackson 2000 watt electric chainsaw. The clutch seems to be getting weaker and weaker, so that if the chain is impeded at all, it just jams and the drive disengages. If I turn off the...
there is no clutch in the drive
just a simple in-out dog engagement
pull the lever back engages the drive and pushing it forward disengages the drive
uncaring operators generally disengage the dog and start the electric motor before engaging the dog and then pull to engage while the motor is spinning
, that action damages the teeth of the dog which results in what you describe
depending on the age of the chainsaw , parts may be available from the service agent or manufacturer spares
Sep 06, 2017 | Garden
How do I remove the door panel and replace the inside door handle
PLEASE DON'T FORGET TO RATE!!
Door Panel
  1. Remove the door handles and the locking knob from the inside of the doors.
If equipped with screw retained door pull handles, remove the screws through the handle into the door inner panel.
  1. If equipped with remote control mirrors, remove the remote mirror escutcheon, then disengage the end of the mirror control cable from the escutcheon.
Door lock remote control handle
Removing the clip from inside the door handle
3. If equipped with a switch cover plate in the door armrest, remove the cover plate screws, then disconnect the switches and the cigar lighter (if equipped) from the electrical harness.
4. If equipped with an integral armrest, remove the screws inserted through the pull cup into the armrest hanger support. If equipped with an armrest applied after the door trim installation, remove the armrest-to-inner panel screws.
View of the armrest switch cover plate and remove mirror cable attachment
  1. If equipped with two-piece trim panels, disengage the retainer clips from the front and the rear of the upper trim panel, using tool No. BT-7323A, then lift the upper door trim and slide it slightly rearward to disengage it from the door inner panel at the beltline.
If equipped with electric switches in the door trim panel, disengage the electrical connectors from the switch assembly.
  1. Along the upper edge of the lower trim panel, remove the mounting screws. At the lower edge of the panel, insert tool No. BT-7323A between the inner panel and the trim panel, then disengage the retaining clips from around the outer perimeter. To remove the lower panel, push the panel down and outward to disengage it from the door.
If equipped with courtesy lights, disconnect the wiring harness.
  1. If equipped with an insulator pad glued to the door inner panel, remove the pad (with a putty knife) by separating it from the inner panel.
To install:
If replacing the inner pad to the door inner panel, use 3M General Trim Adhesive No. 8080, glue it to the panel.
  1. If removed, glue a new inner pad to the door inner panel.
If equipped with courtesy lights, connect the wiring harness.
Exploded view of the window regulator handle
Exploded view of the door trim panel
  1. Engage the retaining clips around the edge of the lower trim panel, then install mounting screws.
If equipped with electric switches in the door trim panel, engage the electrical connectors to the switch assembly.
  1. If equipped with two-piece trim panels, engage the retainer clips to the front and the rear of the upper trim panel.
  2. If equipped with an integral armrest, install the retaining screws.
  3. If equipped with a switch cover plate in the door armrest, engage the switches and cigar lighter (if equipped) harness connectors, then install the cover plate and secure using the plate screws.
  4. If equipped with remote control mirrors, engage the control cable, then install the remote mirror escutcheon.
If equipped, install the pull handle screws through the handle into the door inner panel.
  1. Install the door handles and the locking knob to the inside of the doors.
Exploded view of the 2-piece door trim
  1. If equipped with a switch cover plate in the door armrest, remove the cover plate screws, then disconnect the switch
  1. If equipped with an integral armrest, remove the screws inserted through the pull cup into the armrest hanger support. If equipped with an armrest applied after the door trim installation, remove the armrest-to-inner panel screws.
  2. If equipped with two-piece trim panels, disengage the retainer clips from the front and the rear of the upper trim panel, using tool No. BT-7323A, then lift the upper door trim and slide it slightly rearward to disengage it from the door inner panel at the beltline.
To install:
  3. If equipped with a switch cover plate in the door armrest, engage the switch harness connector, then install the cover plate and secure using the plate screws.
Nov 16, 2009 | 1987 Chevrolet Monte Carlo
How to remove the inside door panel from a dodge 2005 2500 pick up
FRONT DOOR TRIM PANEL - REMOVAL
Release door latch and open door.
Roll window down.
Remove window crank Window Crank - Typical , if equipped.
Remove screws attaching trim panel to door Door Trim Panel and Trim Panel Screw
CAUTION: Do not forcibly pull trim panel from door, damage to trim panel may occur.
Simultaneously lift upward and outward to release retainer steps from inner door panel Trim Panel Retainer
Disengage inside handle linkage rod from inside handle.
Disconnect speaker harness wire connector Speaker And Power Mirror Connector
Disengage power mirror wire connector, if equipped (driver's side only) Speaker And Power Mirror Connector
Disengage clips attaching power window/lock switch panel to door trim panel. Disengage wire connector from switch panel, if equipped Power Door Lock/Window Connector
Separate door trim panel from vehicle.
INSTALLATION
Position trim panel at door.
Engage wire connector for window/lock switch panel, if equipped. Engage clips attaching power window/lock switch panel to door trim panel.
Engage power mirror wire connector, if equipped.
Connect speaker harness wire connector.
Engage inside handle linkage rod to inside handle.
Align trim panel retainer steps with inner door panel and slide trim panel into place.
Install screws attaching trim panel to door.
Install window crank, if equipped.
Hope helped with this; remember rated this help. Good luck.
Nov 12, 2009 | 2005 Dodge Ram 2500 Truck
Blades disengage when they are suppose to engage
Sounds like a faulty switch? This scenario doesnt really make sense. Sorry. Please explain more clearly. Thanks, Mike. Rate 100% please.
Jul 04, 2009 | Cub Cadet Street Sign- tractor lawn riding...
50sbx70b made sizzling noise then quit
Sizzle cound be crt arching or hv transformer. look for burn marks on transformer on deflection board. unplug set and remove crt boards from the crts and see if set will turn on. if replace arching crt. expensive. not to be attempted by amature.
Jun 27, 2009 | Hitachi 51F59 51" HDTV Projection...
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
