Question about Electrical Supplies
I have a mcculooch generator with a wenling jennfeng engine # 5wjf,3382ga:em I am looking for a carburetor for it I believe it is a 11 HP engine but not positive do you have one or know where I can g
That is all just looking for the carburetor for this engine # 5wjf,3382ga:em
    New Friend:
  • 58 Answers
Sometines just clicking in the model # on line finds it . It worked for me. Good luck.
Posted on Nov 26, 2014
5 Suggested Answers
  • 151 Answers
SOURCE: NEED A BRASS PLUG.
check with your local automotive supply the do carry small engine carb kits.They may or may not have your kit but can order it or tell you where to find it.
Posted on Dec 24, 2009
SOURCE: Coleman 5000 watt generator Tecumseh 10 hp engine.
it's running lean.....try resetting the choke partially when it begins to surge.....not completely closed, but enough to richen the fuel mixture (that's all a choke does btw..)
if that helps or clears the problem, your carb is outta whack.....cheaper to buy a new carb than keep taking back into the shop.
Posted on Feb 01, 2010
  • 243 Answers
SOURCE: I have a white wire - approx. 5' with no home that I can see
please connect it to earth(chassis) and look if it is stil sparking. i think it is the wire to stop the gen. it used to be fit behind the handle to start and stop please let me know, thanks.
Posted on Feb 15, 2010
SOURCE: Briggs and Stratton GenPower 11 generator cover plate ???
I have a Briggs & Stratton GENPOWER 11 generator that is electric start. The electric start will not start the motor or ever turn it over. I can turn the key on and jump across the terminals on the starter and it will run only if I continue to squirt starter fluid in the carb. My question is, if the ignition switch is bad, could that be the reason it will not stay running. My only guess is if the ignition switch is bad, the motor thinks it is in the off position at all times. Thanks, R Ray
Posted on Nov 23, 2011
I have a 5000w generator #5wjfs.3892ga.em. It is a wenling jennfeng I need a carburetor
All contacts for this Chinese company seem to have closed down. I can only find spares here, including carburettor (with two t's :) It does however say the part is not available.
Troy Bilt nbsp753 05005 JENN FING 29CC ENGINE nbsp29cc Jenn Feng Engine
Dec 10, 2016 | Electrical Supplies
3000 wat gen 6wjfs muffler,
Wenling Jennfeng makes that unit. It Chinese. Honda parts should fit that engine. You may want to take the old one off, do a thread count and pipe size and see what it takes. It is going to be metric.
Jun 27, 2016 | Cars & Trucks
How can I replace carburetor?
I believe the electric solenoid is a fuel shut off. solenoid needs energized, normally with switch 12 Volts. other then float bowls are the carbs. identical, if they are switch bowls, should work. If not you will have to add switched power to solenoid, the link below looked similar to yours.
Generac Generator Carb removal and disassembly
McCulloch Generator Model FG5700AK
Jan 25, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
I need a parts book for a wenling jennfeng 3800 generator
I have a cheap wenling Jennfeng 3800 generator someone ...
www.fixya.com/.../t25882221-cheap_wenling_jennfeng_3800_generato...
Sep 26, 2015 - I have a cheap wenling Jennfeng 3800 generator someone removed wiring from bridge rectifier i ... If you are replacing parts on the board please send photo. ... Snap-On book says the part number is BC4200-2000R but it.
wenling jennfeng industry 79 5cc generator parts Questions ...
www.fixya.com > Forum > Tags
Find solutions to your wenling jennfeng industry 79 5cc generator parts ... My 6.5 Hp Honda Clone 3800W Wenling Jengfeng 5WJFS.1961GA runs fine off ... Bank Swift Codes I need the swift code for Bank of China Wenling Sub Branch Hi there, don't know if you speak Chinese, but here is a list of swift codes for branches of ...
jennfeng generator parts Unsolved Problems - Fixya
Dec 08, 2015 | Electrical Supplies
What would make a McCulloch FG6000MK 11 HP generator start and idle fine but not able to rev-up and generate power.
Have to an ultrasinic cleaning of the carburetor and see if that will clean up the problem,
Bad on parts though most are NLA. but a carburetor from a Honda 11hp horizonal might work on this Chinese Honda cloned engine.
Nov 24, 2014 | Electrical Supplies
Wenling jennfeng generator governor not working, linkage ok, speed ran away while in use
that doesn't make sense , surely it has a governor how else can the carby rpm be governed , sounds to me like the internal governor thrust counter weight has come out of it's locking plates. if governor arm has been adjust wrong way or moved from it's original position this will happen .
Mar 28, 2014 | Electrical Supplies
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Feb 05, 2010 | Briggs & Stratton Power Products 5,550...
Clone honda 6.5HP engine
hi
valve clearance(cold0
intake 0.005to0.007inch
exhaust0.007to0.009inch
byesavumihai71
Sep 12, 2009 | Electrical Supplies
Electrical Supplies Logo
163 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
