Question about True GDM-12 Refrigerator Commercial
I'm trying to figure out how old my True GDM-12EM is ? Please help?
2 Suggested Answers
  • 906 Answers
SOURCE: GDM-41 Refrigerator: True GDM-41 Refrigerator getting too cold...
good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
My gdm 12em ld is too cold
lower the thermostat.
Oct 07, 2015 | Refrigerators
How do i chage the temperature on a true cooler gdm 49 florial cooler
True GDM-12 Refrigerator... Repair Questions - Fixya
www.fixya.com/support/p22955-true_gdm_12_refrigerator_commercial
Recent True GDM-12 Refrigerator Commercial questions, problems & answers. ...Where is the temp control on the older (14 yrs or so) on GMD-12? True ..
Aug 16, 2014 | True GDM-12 Refrigerator Commercial
True GDM-10 Drink Cooler from 1997...
A good test method is buy a rco-410 hard start relay. Once you have it, cut an old plug off something and leaving the plug intact, splice the two wires at the cut end with the two wires on thet really that don't have metal ends. Once that is done securly, unplug the fridgem take the really off the compressor and hook up the home made compressor tester. Once plugged in if the compressor is good it will come on, it it doesn't it's bad. This works becuase you remove any variables that are present with the machine hooked up normal.
Jun 15, 2012 | True GDM-10 Refrigerator
Where is the temperature control knob for a True GDM-41 refridgerator?
Look inside near the evaporator coil they are usually on the end or in front of the sheet metal cover, they can be hard to find, so the average shopper can't play with it.
Jun 30, 2011 | True GDM-41 Refrigerator
True GDM-72f freezer Fans don't start
Thermo fuse has failed on the core plate, tells the freezer its cold enough to start blowing air, you can bypass it but not recommended. hope that helps, Russ
Jun 11, 2011 | True 72 cu. ft. / 2039 liter Commercial...
L.comTrue model GDM-23 starts and stops(very short cycles10 sec. or so
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
May 15, 2011 | True 23 cu. ft. Commercial Freezer...
I have a True GDM-26. The contents get cool inside but not cold. The temperature dial is set at the coldest setting. Also, there is a lot of condensation on the bottles inside the cooler. Any...
I have same problem was told condensing fan not working properly. Easy to see if this is the problem, take out guard in front of machine and put a fan blowing into it. I went to home depot and bought a tornado fan and it cools again. Now if I can only figure out if its the fan or whatever contros its speed. If anyone knows how to check please respond.
Nov 24, 2009 | True GDM-26 Refrigerator
True Freezer- The 5 amp circuit breaker trips when the light on
I believe that breaker is actually for door frame heaters. Most true freezers have a resettable breaker for the door perimeter heaters only.
Sep 11, 2009 | True 23 cu. ft. / 651 liter Commercial...
True GDM-12 Refrigerator Commercial Logo
67 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
