Question about Pool & Spa
I keep getting a E96 code on my intex pure spa and I seen when other people have asked and we're told it was the Gfi well my husband just eliminated the Gfi and no it still shows code E96 what else could it be ?
    New Friend:
  • 3 Answers
RE: INTEX PureSpa - E96 error code.
This also happened to me, just after having it for 1 year. I followed the scanty instructions in the troubleshooting section to no avail. I called for "technical assistance" twice and got random females with heavy Asian accents and absolutely NO technical know-how.
ME: "I got a E96 error code."
AL (Asian Lady): "When you buy it? If less than year, we send new base."
ME: "It's been longer than that, can I just buy the base then?"
AL: "Yes, $380 and we send it you."
ME: "But I paid $350 for the whole thing new!"
AL: "It's cheaper just buy new one."
ME: "Sure, but can't we troubleshoot this one?"
AL: "We can no more troubleshooting."
No supervisor was available, I was told to hang up and try again for someone else. Persisting, I pried info from one that it was "pump bloken," from the other "bad consore." I believed both were full of it and had no idea what they were talking about.
MY FIX: I disconnected unit from spa. Removed console from base. Turned base upside down to inspect pump and find any ID markings. Found no obvious problem with pump or heating mechanism. Spend few hours time researching cost to buy identical pump. Gave up. Returned to unit, reassembled it, and it worked perfectly!
MORAL TO THE STORY: Intex products are fine, their Tech Support is a joke. I suspect the console had detected air in the pump and that it was stuck in a system error cycle which required a prolonged rest from any power input to refresh. Also, turning the unit over (while inspecting it) may have flushed any remaining water around the onboard pump sensor.
Don't listen to their know-nothing "tech support" when they suggest it is a GFCI problem, (or some of the others here who give this advice without really knowing).
Just keep it fully unplugged for at least a few hours to wipe the system memory!
Since it's a circuit board, it's like a mini-computer. Actually, it's just like a modem that requires resetting. If you unplug it and then replug it too soon, you've solved nothing, the on-board circuitry retains enough voltage to prevent it from resetting. You need to keep it unplugged for an extended period of time.
Hope this helps. Best of luck!
-Matt
Posted on Aug 12, 2015
  • 1,631 Answers
Intex Calls it a "System Error" - they recommend to Unplug, let rest, then plug it back in. If fault continues, call their service center,
But we have found that it is a poor quality GFCI Cord End in the 1st place and replacing it almost always fixes the problem.
DO NOT ELIMINATE THIS PIECE OF LIFE SAVING EQUIPMENT!!
Look here for a good replacement:
Leviton 16693 15 Amp 120 Volt Grounded Compact Automatic Reset Right Angle...
Posted on Apr 11, 2015
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
The code is indeed for GFCI issue.
But if you eliminate the GFCI not only is it fatally dangerous to the users of the spa. But the internal components know it doesn't have GFCI protection due to the monitoring of the Neutral conductor.
Probably had the original GFCI wired wrong to get the initial fault code.
Posted on Nov 12, 2014
2 Suggested Answers
jerry_kramer
  • 3904 Answers
SOURCE: intex spa
You have a bad GFI plug. Replace it and you should be fine.
Posted on Apr 13, 2014
Sorry what dose e96 code mean
It is helpful to post device (or vehicle), brand, model, and sometimes year when posting a question. For instance, this question was posted in cars and trucks. But as code numbers are sometimes by sheer coincidence shared with other devices, this number is the code for an error related to a spa:
Intex Pure Spa E96 slow reset solution
Aug 08, 2017 | Cars & Trucks
My Intex spa turns on heat light comes on ,only for about 2 minutes and then goes out then flashes e96 and is beeping, How do I fix ?
If alarm code E90 is displayed on the control panel, it means no water is flowing through the system. Check the attached troubleshooting guide.
Mar 14, 2016 | Intex Pool & Spa
How can I fix code E96 ?
The E96 error code t - the control console (the bottom part with the pump. call intex customer service and order a new one, you need your receipt.
Jan 17, 2016 | Intex Pool & Spa
What errors does Intex E96 code cover
make sure pump is primed
Sep 14, 2014 | Pool & Spa
Intex spa
Apr 13, 2014 | Intex Pool & Spa
E96 error code
E96 - On what?
Need more info.
E96 on intex spa pump
I do not know what that error code is however I can tell you most of those kinds of spa take around 24 hours to heat up.
What model name of Intex Spa do you have?
Rod
US Parts Center
Apr 12, 2014 | Intex Pool & Spa
Pool & Spa Logo
3,392 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
